Matt's Gedlee Summa Abbey Kit Build
Thread Tools
Old 5th February 2020, 04:03 AM   #521
Drofdissonance is offline Drofdissonance  Australia
Originally Posted by camplo View Post
happens on the vertical axis....non the less.
Thats what you expect for all speakers in this kind of configuration with a crossover that high.
Wavelength at 1.7k is 20cm so we are trying to get the 2nd source within 5 cm Center to center to avoid this issue.
most studio monitors suffer from this issue. Genelec just isn't hiding it at all
Old 5th February 2020, 07:23 PM   #522
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Am I the only one noticing that you can't get perfect signal unless you are within 15 degrees of center....all that effort and it still beams. The beamingClick the image to open in full size. happens on the vertical axis....non the less.
I wrote this article that explains it: What Causes Off-Axis Nulls?
It's something that's common to nearly all two-way loudspeakers with a waveguide. It's caused by the center-to-center spacing.
Old 8th February 2020, 05:58 PM   #523
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by Thinkcat View Post
I will then build the one on the right. But still I wonder, since these are both from an email message that is dated November 2012. Is it possible that there was some other change back then? Or already some development with DE500.
There was no development of an Abbey with a DE500, none were ever built. But there were always small changes to the crossover design for a myriad of reasons, but they all worked basically the same.
Earl Geddes Gedlee Website
Old 8th February 2020, 09:00 PM   #524
camplo is offline camplo
Thanks Patrick. I'm realizing information that I should of known already, and probably had this explained once already...I feel like the cross over, group delay, and phase all paint a picture in the polar, one that I cannot simulate with xDir.
Old 19th March 2020, 08:15 PM   #525
Thinkcat is offline Thinkcat  Finland
Of the crossovers, one has twice 0.5 mH inductor, another has twice 0.45 mH inductor. Do you think I'd be fine with 0.47 mH ones in either case?
Should I prefer 0.83 or 0.36 ohm series resistance for those inductors? Is lower always better here?
Also, instead of ordering parts so that I can build either one of the crossovers, I think I should settle for one or the other. If those are equal in performance, I think I will see which parts are more easily and readibly available. I'm going to order these from TME with some other stuff for a few unrelated projects.
Old 19th March 2020, 08:55 PM   #526
gedlee's Avatar
The value of .47 won't make much difference. The lower ohms is better for those inductors.
Old 22nd June 2020, 09:33 PM   #527
Getting ready to order the parts from TME. I assume it's not good to use "ordinary" resistors or capacitors, so I'll order what they call generally "audio grade" stuff.
A 2 mH coil does not exist, therefore I go with the crossover that has a 1.5 mH one. Those are available. I could find all the capacitor values except one. I make 3 F capacitors out of two 1.5 F (instead of, say 1.2 + 1.8). I have a capacitance meter for matching them. But does it matter otherwise?
Now only thing left is a 6 Ω resistor. If I combine one 2.7 Ω and one 3.3 Ω with half the power rating, I think I'll be good. Do metal film versus wire wound ever make a difference here?
Old 23rd June 2020, 05:33 PM   #528
gedlee's Avatar
Parallel capacitors work fine. But, two resistors in series will not double the power rating of any one, but it does lower the current in each, meaning that less power is dissipated. I tend to avoid "audio grade" parts as mostly scams, but you do have to avoid electrolytic caps as they can be problematic.
Old 15th September 2021, 03:11 AM   #529
jdubs is offline jdubs  United States
Hey all, does anyone know which MiniDSP plugin is suitable for Earl's Abbey XML file? I sent it to MiniDSP and they couldn't figure it out.
Thanks!!
Jim
  Reply to this post
Matt's Gedlee Summa Abbey Kit BuildHide this!Advertise here!
Thread Tools
F1 or F2...which should I build for an Abbey audionut Full Range 3 28th June 2009 03:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
