Ultimate Open Baffle Gallery
Old 22nd November 2019, 11:17 PM   #2771
MITsound is offline MITsound  Canada
MITsound's Avatar
Originally Posted by planet10 View Post
Bernie actually made them. Solid Mahogany IIRC. A hifi stand in the same too. Drivers EnABLed, wired with solid core cry-treated 24g, with WBT next gen banana plugs.
I really like the A12pw. And i much prefer the A10p to the A12p. We have a floor-stander & the sand-mount version pictured for these. The A12pw is killer in a Woden ML-TL. We use a pair with A7.3eN in a WAW. I have no reason to dipubt the sims that suggest response to the mid 20s.
Top end really starts to disappear above about 10k. It makes XO very flexble if you decide to use them in a 2-way. We XO the WAW at 250 Hz, Scott to the A7p at about 1kHz (example below build by Mario shown at the latest BAF — i saw a better pic, ut this is what i could find quickly), or to a dome or ribbon between 2-5kHz.
Ultimate Open Baffle Gallery-mario-a12pw-apen-jpg
dave
The standpoint ones look similar to my friend's.
Martin's are solid walnut, I think, and also beautiful in fit and finish.
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 22nd November 2019, 11:19 PM   #2772
warrjon is offline warrjon  Australia
Originally Posted by Peter Campbell View Post
The W frame gets you to how low a frequency? 30 hz or lower?
What freq/slope do you cross to FR?
I'm not sure how low they go I have not measured that. I only measured at the XO point from 100 to 5kHz. XO is set at 235Hz 24dB LW. I used Rod Elliot's kit P09 for the XO.
They sounded so good I moved on to get my analog rig working as it should, when I'm done with this I will go back and measure and tweak the speakers.
SP10, ...... EPA-100, ......EPC-205CII, .....BHL phono,.........Pass B1,
MODULUS 86 power amps x4,.............Active line level OX,......... bi-amped OB speakers with Mark Audio Alpair 12P
Old 22nd November 2019, 11:22 PM   #2773
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Its the same guy. Only 1 pair of these standmounts have been built. I guess it was Bernie’s FHXL build fron Steve that were Mahogany.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd November 2019, 11:29 PM   #2774
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It's the diffractions of the rectangular baffle that are smoothing the response Frequently Asked Questions I wonder how much smearing of the image this causes Diffraction from baffle edges
Old 22nd November 2019, 11:48 PM   #2775
In my experience quite a bit as does baffle vibration.
The additional detail adding baffle damping is very audible. as is de-coupling the FR from the woofer vibration. Each step that added detail was kept. You can see the table over the woofer this made no audible difference so was discarded.
Here are a few iterations of my development. Pic 2 and 3 should be reversed. Pic 3 was the woofer box from Pic 1 cut down same W300 woofers.
Pic 4 sounded very shouty and it was the raised edges of the trim around the baffle causing the midrange peak. Pic 5 is the same baffle cut and chamfered 45deg, sounded much smoother.
Old 23rd November 2019, 12:03 AM   #2776
MITsound's Avatar
Do you prefer chamfering over a roundover?
Old 23rd November 2019, 12:06 AM   #2777
I think maybe you should use felt on the rear of the baffle too, for symmetry
Old 23rd November 2019, 12:18 AM   #2778
I prefer the felt over chamfering, never tried the roundover, problem is the chamfer needs to be a large radius to work effectively, my baffle is only 12mm thick, this is why I used felt. I also had a copy of the BBC design document for the LS3/5A (which I can not find ATM) and their use of felt was preferred over other methods of controlling these artifacts.
I tried felt on the rear and could not hear/measure any difference so I removed it. I do have sound absorbing panels behind and inside the speakers, these make an audible difference to the depth of the image. I suspect reflections from the TV are the issue there.
Old 23rd November 2019, 10:18 AM   #2779
Peter Campbell is offline Peter Campbell  Canada
Your mounting method has me thinking, vibrations on the PAP frame are quite large. This is why it’s good to join here, thanks.
Old 24th November 2019, 10:23 AM   #2780
I've spent 10 years refining this design, reducing the vibration of the baffle has IME far more effect than isolating the FR from the woofer. Although the W frame reduced vibration and a forward mount woofer may introduce IMD.
I made the magnet mount from 12x3mm aluminium bar. To form it I used 18mm plywood circle cut the same diameter as the magnet.
First I bent the mounting flanges at 90deg, this needs to be accurate or the FR will sit at an angle.
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 05:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 01:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 02:00 AM
Copyright ©1999-2019 diyAudio
