Ultimate Open Baffle Gallery
Old 18th May 2019, 01:07 AM   #2661
MITsound is offline MITsound  Canada
MITsound's Avatar
Default Higher, lower, or sideways?
I'm again trying a 4 way.
Three way active crossovers, and now passively splitting the treble at 6500 Hz, Solen Split.
Using a JBL Selenium midrange allows a lower crossover point, to the woofers, so far 800 Hz is working well, with an improved smoothness , over the Peerless crossing near its lower limits, and the Celestions crossing near their upper limits.
I think they look better with 2 horns per channel, too.
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 24th May 2019, 07:38 PM   #2662
RE 604 is offline RE 604  Germany
RE 604's Avatar
Hello ,
here is my open baffle project . 24 zoll Fane "Colossus" , JBL 2360 with BMS coaxial drivers . For mid and high I use single ended amps with RE604 and E406N and EL86 push pull for the bass . The active crossover is from Behringer , the final version is a tube crossover in the future .
Kind regards , Alexander .
No reason to get excited : Jimi Hendrix .
Old 27th May 2019, 09:45 PM   #2663
mordikai is offline mordikai  United States
Send a message via Yahoo to mordikai
Wow!! I like it!
Old 28th May 2019, 10:55 AM   #2664
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
Alexander,
this is one of the few systems out there that I would really like to listen to!
If nothing should exist, the possibility itself that nothing should exist, does not exist!
Old 30th May 2019, 10:04 PM   #2665
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
A friend of mine with his creation of an OB speaker .
Drivers are SB Acoustic SB34NRX75-16 , Scan Speak 18WU4741T00 , Scan Speak D3004/66400 Beryllium
Old 31st May 2019, 10:58 AM   #2666
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Nice and basics handled in right way! Obviously dsp-xo? Do you have a link to this build?
Pretty much a clone of Kyron 6moons audioreviews: Kyron Audio Kronos
Radikal aktivist AINOgradient speaker project
Old 31st May 2019, 03:04 PM   #2667
gadut is offline gadut  Indonesia
gadut's Avatar
it was posted in OBO fb group, but it also can be found here ZBA page
however no detail on that page, while the builder give information on OBO group
Open baffle only... Public Group | Facebook
some quotes :
DSP: Lyngdorf TDAI-2170 (without Room Perfect).
"Kronos was not my reference. I had this baffle design already before the Kronos and even before the Illuminator came available"
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 31st May 2019, 04:17 PM   #2668
Gonna build the same speaker but with slightly different baffle .
At this moment the speakers of the builder use passive and active xovers .
Mid and high with passive xover and the bass section uses the Lyngdorf filter which now has the room perfect module .
If you need more info just send me a private mail .
Old 1st June 2019, 03:53 AM   #2669
ttan98 is offline ttan98  Australia
Originally Posted by meanman1964 View Post
rotate pic
My Open Baffle looks similar except I installed a rear tweeter behind the front one. This arrangement should sound very good.
Old 1st June 2019, 07:32 PM   #2670
jerome69 is offline jerome69  France
jerome69's Avatar
Default Four way OB
My latest design. A compact passive OB 1.1x0.3x.0.25 m - 43x12x10". Four ways - U frame for the bass.
1" DX25 : 3.5k-20k LR4
5" 830991 : 500-3.5k LR2 & LR4
8" 22W/8534G00 100-500 LR2 & LR2
2x10" SLS263 30-100Hz LR2
An upgrade : go to a compact H frame like he-hurricanes
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Copyright ©1999-2019 diyAudio
