Thanks for the reply just curious what is the celestion and compression driver crossed over at is it like the bastanis at 7khzi have made the phase with a woodturning machine,it's spruce, the felt pads is just furniture pads and the cone is treated/dopped with JOHA oil varnish
I am still waffling between open baffle single drivers without or with helper tweeters.there is no anaomalies, not what i can hear
Just now I've stuck with some independently mounted and aimed 1 inch 4 ohm domes, with 2uF caps bypassed with some 0.01uf foil in wax paper caps I've had for ages.
I'm surprised at still gradually preferring less and less upper treble. I've gone from 8 ohm more efficient tweeters with the same few caps to 4 ohms , for more efficiency and higher frequency.
Iteration of my own system. Revolves around Vifa P13WH mid and tweeters, cheap woofers from Jaycar, and another pair I found on the side of the road
My first was very easy. Large room allows large baffle. Very satisfiying.
Hi! Fisrt time in DIY audio forums and came across this thread with your open baffle builds. Wondering if you have a build thread I can follow? Especially interested in the build in the final picture and wondering if these are successful as close to the wall as you have pictured them?
DonnF, please check his homepage https://gainphile.blogspot.com/
Other good sites about dipoles/open baffles - you must understand the physics...
https://www.linkwitzlab.com/
https://musicanddesign.speakerdesign.net/products.html
http://www.dipolplus.de/
