Ultimate Open Baffle Gallery
Old 25th September 2018, 02:30 AM   #2541
perceval is offline perceval  Taiwan
perceval's Avatar
Originally Posted by umut1001 View Post
Hi.Thank you for your suggestions.I am sure these speakers are great sounding.Sorry i showed them to both wife and daughter and sorry they did not like them.
Width should not exceed 25cm.Depth no problem.Height should not exceed 120cm.(these are the criterias)
It is better the drivers is not seemed and speaker to be white coloured high gloss.
Then, do not do real open baffles.
Unless you are happy having small tiny sound and no bass.
Here's another option combining small and OB sound.
The Nola Brio Trio.
Two small enclosures, two drivers per side, one is vented, the other is OB.
They will need one or two subs that you can hide somewhere in the room, under a table, under the couch, etc...
There's a thread to DIY them here:
Need help building open baffle/bass reflex hybrid
Just paint them white instead of black.
Ultimate Open Baffle Gallery-screen-shot-2018-09-25-10-26-27-am-png
File Type: png Screen Shot 2018-09-25 at 10.26.27 AM.png (700.7 KB, 815 views)
Old 25th September 2018, 09:38 PM   #2542
umut1001 is offline umut1001  Europe
umut1001's Avatar
What about cross positioning or side positioning of alpha 15 bass drivers to decrease width of speaker?
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.net
Old 26th September 2018, 02:34 AM   #2543
mkane77g is offline mkane77g  United States
Always Learning
anythings possible
Old 26th September 2018, 03:13 AM   #2544
PjVervoorn is offline PjVervoorn  Thailand
I have built a pair of N-Frames, 2 12" drivers per side.
They are symmetrical (left and right are mirrored), easy to build.
On top I have JBL 308 monitors (no time or skills to do a complete speaker.).
Only 25cm wide is quite small, but you could make them smaller.
The photo is from the rear side btw.
Old 26th September 2018, 06:15 AM   #2545
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Baffle dimension is very important factor when designing and evaluating open baffle speakers. A semi-open box like NOLA uses is weird and the N frame in the previous post works right only below 1000Hz - and are very prone to resonances.
Soundwave length variation in music is the problem here, soundwave bending and summation must be undestood well. That is why best results come from 3-4 way speakers with variable baffle width/dimensions. A narrow open line needs a different solution for mid- bass below say 300Hz.
Good reading here
Electro-acoustic models
Tech
Dipolplus - Alles über offene Schallwände
AINOgradient speaker project
Old 9th October 2018, 01:16 AM   #2546
MITsound is offline MITsound  Canada
MITsound's Avatar
Default 322
Sort of winging the baffle size for this.
Tested the concept with a 16x48" baffle, with the midranges and tweeters just screwed to the side of the try baffle.
Still awaiting delivery on a second pair of Neo 10 Bohlender Graebeners.
Still awaiting delivery of 4 Celestions 1525e-4, 15 " woofers.
Made two of these tonight, but I'm too lazy to cut out the tweeter holes.
The plan is, a Neo 8 ( I think mine are PDRs) splitting treble with a Neo 3PDR, 1 slope passive at 6000 Hz, actively crossed 4 slope to two BG Neo 10s, at 2500hz, actively crossed to the woofers, also 4 slope, at 175hz.
The two tweeters will share an amp channel, as will the two midranges, and will be vertically biamped with some nice little class a amps, 15 watts into 4 ohm loads.
The mixing of a total of two 4 ohm bass drivers, and one 8 ohm bass driver per channel allow for a few wiring and amping options, but I will start with them as a 4 ohm load, and a stereo Behringer A500 I've had around for a while.
This started out as a smaller alternative to my home made Onkens, with 511B and B+C horns.
Now they'll be a couple inches wider, and taller, at 24.5" wide, and 60" tall.
I'm hoping these will match the Onkens for dynamics, be a little smoother, and have better bass, that's less intrusive on my apartment neighbours.
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 9th October 2018, 01:49 AM   #2547
Always Learning
Good reading here
Tech
looks familiar
Old 10th October 2018, 03:00 AM   #2548
MITsound's Avatar
Originally Posted by mkane77g View Post
looks familiar
Form follows function.
Has anyone tried a satin or semigloss latex paint on their projects?
I plan to paint my baffles à la Eddie Van Halen's guitar scheme, red field, black and white stripes.
I ask, because I'm hoping some car wax and a buffing pad will shine things up, without me needing to outsource the painting to a shop.
Old 10th October 2018, 10:53 AM   #2549
6thplanet is offline 6thplanet  United States
6thplanet's Avatar
I dunno about car wax and buffing pad on latex paint????
Old 10th October 2018, 08:41 PM   #2550
MITsound's Avatar
Did a test, and it works fine. Not able to set up a spray booth in my apartment, and every polyurethane finish winds up with dust particles in it. This way, an inexpensive cut polish leaves a very good surface.
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
