Ultimate Open Baffle Gallery
Old 7th January 2017, 05:06 PM   #2211
Xerxes75 is offline Xerxes75  Netherlands
Curlycat...
I was looking at your wonderful loudspeakers (aren't does ripole subs?). But what really caught my eye is the futuristic looking thing in the background is that your amp?
R.
LM3886, LM4780, DCB1, DAC, First One v1.3, vintage drivers..
Old 7th January 2017, 05:28 PM   #2212
Curlycat is offline Curlycat  South Africa
@ PDRCanada - Indeed They are Fostex FE126EN drivers, with Silver Flute tweeters. I am using the miniDSP HD to run the setup between the LF & HF sections. The tweeters have a passive XO crossing at 7KHz. The woofers are 12" Agent Audio LS-1093 drivers.
@ Xerxes75 - Thank you! You are right, they are also called Ripoles. In the background is my DIY naked amp, with 3 stereo channels.
Old 7th January 2017, 09:54 PM   #2213
YashN is offline YashN  Canada
Originally Posted by Curlycat View Post
My Slot Loaded Open Baffle.
Thought I saw your S.L.O.B. on an SA forum recently: the open-air amplifier was there too.
The front of the S.L.O.B. only have one open slot in the center, a true Ripole, right?
Great work!
Old 15th January 2017, 12:22 AM   #2214
avincenty is offline avincenty  United States
Default 4way open baffle test
Finally was able to do a 4 way open baffle test. I used drivers i had on hand except for the mid MU10RB. LOWs are Beta 15A i parallel with a Hartley 220, low mid are 8 inch KRK Kevlars woofers and the tweeters are dipole sawafujis. I had to wait a while because i did not have the 8 channels of amplification. I found locally for $75 two altec 2204A amps, one had a few bad channels. A good cleaning off all connectors brought all channels back. The crossover is with two Minidsp 2x4. I had purchased the plans for the Nao Note ii RS and wanted to get an idea of what it could be before investing in new drivers and better amps. I customized the crossover and eq to match my drivers.
The bottom baffle is from an old speaker cabinet, only kept the front baffle. The top baffle looks similar to the LX521. Different angles on the top mid and tweeter. I figured that since the tweeter is a true dipole that rounded edge would look better.
This things sound fantastic, i am convinced! My wife sat next to me and first asked if all the speakers were turned on. Speakers in the back are KEF104/2 and there is a unhooked subwoofer on the center. Then said it was like seating on the front seats at a concert (was playing Vivaldi at the time).
The speakers dissapear and the whole back wall becomes a stage. I played it loud and it is a very different loud to box speakers, the bass is ver clear and palpable but there is no pressure in the room. It sounds really good everywhere in the room, even 35 feet back.
Definitely something to consider for those that have the space to move away the speakers from the back wall.
Next step is to buy better gear, first thinking to get a new DSP and the SLS woofers and make a new lower baffle.
Will continue to enjoy these until the next revision.
Old 15th January 2017, 11:38 AM   #2215
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
YashN, I noticed in your design that there's a few millimeters gap between magnets and wood, and according to my experiments this of very little significance.
Just for everybody's knowledge.
If nothing should exist, the possibility itself that nothing should exist, does not exist!
Old 15th January 2017, 07:25 PM   #2216
juliopr is offline juliopr  Puerto Rico
This is the response graph from listening position of my open baffles...
File Type: jpg 16111309_10154900528215349_770074709_n.jpg (30.3 KB, 1540 views)
Old 15th January 2017, 08:01 PM   #2217
JonasKarud's Avatar
Can you show a graph with the usual 50-60 dB span?
Old 15th January 2017, 08:05 PM   #2218
DieterK is offline DieterK  Germany
DieterK's Avatar
What are the bass chassis you used?
Best Regards
Dieter
Old 15th January 2017, 08:39 PM   #2219
Do you mean the baffle?
Old 16th January 2017, 05:33 AM   #2220
DieterK's Avatar
Yes, i mean your baffle. I think the frequenzy response is also from your baffle!?
Best Regards
Dieter
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 12:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Copyright ©1999-2019 diyAudio
