Ultimate Open Baffle Gallery
Old 21st September 2015, 10:18 AM   #1721
Poultrygeist is offline Poultrygeist  United States
Old 21st September 2015, 12:33 PM   #1722
Leonidas is offline Leonidas  Netherlands
I'm impressed !! How do you keep the FE126 (?) vertical with thin lines ? Lotta tension?
Leon
Old 21st September 2015, 01:05 PM   #1723
fishing line and eye hooks with tension
Old 21st September 2015, 01:10 PM   #1724
Naked baffle ; I like !!
Leon
Old 22nd September 2015, 09:54 AM   #1725
CLS is offline CLS  Taiwan
Or you may find the center of gravity of the driver by trial and error. Find a way to support it at that particular position, then it'd be vertical without tension.
It's mostly around the 'neck' between frame and magnet.
Old 23rd September 2015, 09:10 AM   #1726
cradeldorf is offline cradeldorf  United States
cradeldorf's Avatar
I thought it was mounted in plexiglass at first. seems like it would cancel itself out quite early.....
If only time will tell, then obviously time is a snitch.
Old 23rd September 2015, 11:26 AM   #1727
No baffles aren't something I dreamed up. There are many examples on the net.
Old 23rd September 2015, 04:22 PM   #1728
Godzilla is offline Godzilla  United States
Godzilla's Avatar
How does this sound without a baffle? How are you integrating the woofer?
Cool.
Old 23rd September 2015, 10:48 PM   #1729
Very open sounding
I bi-amp with an active crossover.
Old 24th September 2015, 08:15 AM   #1730
Cinek2030 is offline Cinek2030
And what is the xover frequency? How much OB eq is applied to Fostex?
Ultimate Open Baffle GalleryHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 05:26 PM
Ultimate Open baffle for tannoy red 15 inch murphythecat8 Full Range 20 30th January 2013 01:29 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 02:00 AM
Copyright ©1999-2019 diyAudio
