The Pencil: inspired by Ohm Micro Walsh Tall
Old 15th November 2011, 03:53 PM   #91
Cambe is offline Cambe
fwater:I really don't know if the original designer knows something we both don't, like actual measured spec's. I have tried to contact Jusper about this design and so far no response. That is why I am posting here. Please, do check
another modeler and get back to me.
critofer:Just checked the design featured on Troels website for the Peerless HDSPPB830860. 8.2L, Fb= 58Hz, Port= 40mm (ID) x 70mm or 50mm (ID) x 120mm. Like I said above,I do not have any software to use for the enclosure or crossover design. If necessary I will purchase the Morel MDT-40's and use the 2.2 uF capacitor crossover Jusper used. However, the price of the MDT-40's
@ $81.00 ea. from Madisound is not what I really want to do if I don't have to
I really appreciate you guys!
Old 16th November 2011, 12:50 AM   #92
fwater is offline fwater  United States
fwater's Avatar
Well, I've sworn off WinISD before because of inconsistent (with other simulators) results, but sometimes it's just so quick. Hornresp, which I trust, shows good results in 15 liters (-3dB @ 40Hz), but 10 liters is pretty good for this woofer, too (-3dB @ 50Hz, -10dB @ 40Hz). I say go with the stock enclosure to ease the build. Squeezing out a few extra Hz with a bigger enclosure might be worth it if yo want to shuffle the cab around a bit.
In 10 and 15 liters, this port gives both tunings.
Old 16th November 2011, 12:52 AM   #93
fwater's Avatar
BTW, don't drop the bucks on the Morel units. Your tweets will do just fine. A few different values of reasonable caps on hand will let you dial it in with a little experimentation.
Old 16th November 2011, 05:32 AM   #94
fwater, thank you.
Old 18th November 2011, 02:29 PM   #95
fwater you have Email.
Old 25th November 2011, 02:49 PM   #96
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi Cambe:
As requested in your PM: Submitting simulations using your 'Pensil' data:
b
Old 9th May 2014, 01:31 PM   #97
OhioTanner is offline OhioTanner  United States
any news on this front? since the other walsh thread was resurrected, a micro walsh could be in my future...
Old 12th May 2014, 11:10 PM   #98
critofur is offline critofur  United States
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Hello,
Are you in Ohio? I moved to Columbus after developing the MicroWalsh series with John at Ohm Acoustics. I'd be happy to meet with you to talk about speakers, if you'd like.
B.t.w., I'd recommended the slightly larger 1000 model.
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 10th March 2018, 04:03 AM   #99
R. Jamm is offline R. Jamm  United States
Default Updates on the Pencil?
Most likely the drivers used in the Pencil speaker are no longer being made-- do you have any suggestions?
Do you have any plans using an 8 inch driver?
Old 10th March 2018, 02:12 PM   #100
critofur's Avatar
Ohm uses an 8" driver in the 2000, but I prefer the 1000 model, even though it's a smaller speaker - it's particularly impressive for it's size.
Critofur
The Pencil: inspired by Ohm Micro Walsh TallHide this!Advertise here!
Micro-power, micro cost amp with Rod-Tubes, 1P24B-V Alastair E Tubes / Valves 2 12th July 2015 08:22 PM
DIY Walsh Driver cjh Planars & Exotics 40 20th June 2015 04:15 AM
Walsh driver Jaroslaw Sobolski Planars & Exotics 5 13th January 2014 03:29 PM
Ohm Walsh 2 need advice Sk8Ter Full Range 1 4th September 2011 05:51 PM
Copyright ©1999-2019 diyAudio
