Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
#2481 |
Absolutely. I couldn't find my pair of pots so I included them in an order to buy a pair for front and back firing tweeters for my subsequent project and included a pair with the intent of using them for level matching in my next project with the tweeters (and then replacing with a resistor of the proper value) that I thought I might use to circle back and get more granular resistance values on these. I did manage to zero in to within an half ohm of where I want it and honestly, when I measure a lot of resistors they are off from 5-10% in tolerance to where a half ohm is really only a little bit more of a deviation than would be incurred just by crossover component variance. That said I likely still will do it it just has diminished importance in my project hierarchy. While I enjoy these and evaluate them the next few weeks I'll be assembling an h-frame 15" eminence alpha pair for use as a platform upon which to experiment with different mid or mid tweet combos.
The first application will be a pair of 12" Zenith 49cz1045 alnico units on h frames. Will feed the h frames with low frequencies via active crossover up to about 250hz . Above 250hz will be the Zenith running full range and then I will have a wired pair of supertweeters (horn loaded silk domes instead of compression/titanium/planar because I just prefer silk domes) that have a slightly higher efficiency than the Zenith. I will put a single 2uf cap inline on the tweeter to roll it off at 10k and will employ the lpads for level control on the tweeters. |
#2482 |
Photos attached.
#2483 |
Very nice, thanks for the pics!
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 10:00 PM |
Looking to buy inexpensive... | nelsondog | Chip Amps | 0 | 15th October 2004 04:04 PM |
Inexpensive project, which to choose? | manxam | Multi-Way | 12 | 28th December 2003 04:51 AM |
New To Site? | Need Help? |
