Fast, fun, Inexpensive OB project
Old 22nd October 2019, 11:25 PM   #2101
fullrage is offline fullrage  United States
Default Dual 15s manzanita
which 8" fullrange did u use sir ?
Old 23rd October 2019, 01:01 AM   #2102
Pano is offline Pano  United States
Pano's Avatar
I tried a few 6.5 and 8 inch that I had on the shelf - even some Saba green cones. Ended up with an old VOM (Phillips?) fullrange. Gave the speakers to a friend when I moved, he still has them and loves them.
Hard to say what to pick without going crazy in cost. I have some FaitalPro drivers that might work - but haven't ever tried them in the Manzie. Others here will certainly have some suggestions.
Take the Speaker Voltage Test!
Old 23rd October 2019, 01:02 AM   #2103
carlthess40 is offline carlthess40  United States
How would it work with the b&c de10 compression horn driver? I think itís 102db at one watt
Old 23rd October 2019, 01:04 AM   #2104
Pano's Avatar
That's going to depend on the horn. Since you'll be crossing circa 700 Hz, you'll need a big horn.
Old 23rd October 2019, 01:11 AM   #2105
Default Big 8" manzanita
Wild BURRO,makes a full range 8" that may do well.
Old 23rd October 2019, 01:16 AM   #2106
Skip Pack is offline Skip Pack  United States
I would suspect that the second GRS might be better used as part of a 2.5 way configuration, low-passing it in at half the existing crossover freq or so. You could also deepen the wings on the bottom GRS. The interaction with OB cancelation would be the focus. Not an utterly simple adventure.
Skip
Old 23rd October 2019, 09:21 PM   #2107
John Busch is offline John Busch  United States
John Busch's Avatar
Default Dual Woofer Manzanita Ultra
Second try.... I did design and build a dual woofer commercial Manzanita Ultra from 2012-2017. Model Manzanita Ultra Plus! It utilized a Seas Prestige 8 inch full range, P/N FA22RCZ. (Seas H1597-08) As Skip Pack discussed in his post, not an easy design to get right. The crossover used 14 component parts. The Ultra Plus performed well, both as an Audiophile and home theater speaker..... but did not sell well primarily due to its size. The Seas 8" is still available from Madisound and others. Will try to post a picture in a separate post. J
Commercial Website: https://manzanita-audio.com/
Old 23rd October 2019, 10:30 PM   #2108
Pano's Avatar
I did use some Wild Burro prototypes, can't remember if 8" or 6.5" They worked well.
Old 9th November 2019, 08:41 PM   #2109
sujat is offline sujat  India
Could you please let me know the mechanical power handling of the speakers in watts/channel? Does this power handling figure depend on the thermal rating quoted by the manufacturer, or is it totally independent in an open baffle?
Old Yesterday, 12:38 AM   #2110
John Busch's Avatar
Sujat.. Your question is a good one... However, there are so many variables... in the pro audio world, power dissipation is quite important... but in a residential hi fi Open baffle application it is of little value. Most open air, lightly loaded woofers can be driven to Xmax with as little as 15 watts. So, as you postulate, the electrical dissipation quoted by the manufacturer means very little in an OB application.
Fast, fun, Inexpensive OB projectHide this!Advertise here!
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
Looking to buy inexpensive... nelsondog Chip Amps 0 15th October 2004 04:04 PM
Inexpensive project, which to choose? manxam Multi-Way 12 28th December 2003 04:51 AM
Copyright ©1999-2019 diyAudio
