Making diy foam/rubber surrounds
Old 30th September 2007, 09:20 PM   #1
Conrad Hoffman is offline Conrad Hoffman  United States
Default Making diy foam/rubber surrounds
Yes, I know the commercial ones are fairly inexpensive, but what I really want is rubber, not foam. It seems like it would be easy to make a circular half-round groove in a piece of wood or plastic using a router, then apply some mold release and paint it with liquid rubber or 2-part RTV. Strip it out and there's your new surround. Has anybody tried something like this?
Old 30th September 2007, 09:28 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Sounds like a fun experiment whatever way it turns out. Give it a go, and report back.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 30th September 2007, 09:33 PM   #3
Magura is offline Magura  Denmark
Magura's Avatar
I have made similar silicone structures in the past. You will need to make a mold and cast it instead, as you can't controll the thickness of the material otherwise.
Counting that little detail out, it's fairly easy and simple to make such. I would go for a sillicone based compound, as you can relatively easy control the hardness of such a compound, and it can be changed by simply changing the propotions of the mix.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 1st October 2007, 04:54 AM   #4
Hmm... that little detail. I have a mill/drill and rotary table, so making the half round depression is no problem. I'll have to think about how to make the mating half of the mold. There are radius cutters that would do it, first on the ID, then the OD. Same thing can be done with the router, but I don't know how successful I'll be making parts that mate accurately enough to keep the thickness constant. I assume they make the commercial ones the same way, but with better tooling?
Old 1st October 2007, 05:13 AM   #5
PB2 is offline PB2  United States
PB2's Avatar
What driver are you trying to repair, if you don't mind my asking?
This is an issue with the Audax woofer in the SPICA TC-50.
I had this idea exactly, but never gave it a try.
Pete B.
Old 1st October 2007, 06:13 AM   #6
HIPCHECK is offline HIPCHECK  United States
HIPCHECK's Avatar
here is a nice site about diy speaker prototype
http://www.moraalacoustics.com/TestingDiary.htm
Old 1st October 2007, 01:53 PM   #7
OzMikeH is offline OzMikeH  Australia
Mill the Negative half flat in the mill first, then cut the groove without disturbing it. Mill the positive haf flat then put a series of holes around the circle in the flat piece and put short screws in. Coat the negative half with release agent. Clean the positive half with the screws. Assemble and fill with epoxy. This sticks over the screws and makes the positive half of your mould.
Use plates of sheetmetal to space the two halves of the mould apart to form your flanges and to allow you to change the thickness by changing the bits of sheetmetal.
While you're at it you may as well add a feathered or patterned inside edge if you're into the Enabl/Mamboni thing.
Old 2nd October 2007, 12:10 AM   #8
On further thought that won't work if you go with a full semi-circular shape to the surround. You'll end up with three separate pieces. A slight scallop of about a quarter of a circle should work but you might not get the excusion you want.
Old 2nd October 2007, 12:16 AM   #9
Magura's Avatar
The way to go about it is to use a radius mill and your rotary table. That's the way we did it before CNC equipment became an option.
Make sure you incorporate a couple of cylindrical guides to align the two halves.
Magura
Old 2nd October 2007, 12:27 AM   #10
Magura's Avatar
Hasco has a lot of relatively cheap components for this sort of job.
They are sure my preferred supplier, as they also offer top of the line support.
www.hasco.com
Magura
Making diy foam/rubber surroundsHide this!Advertise here!
Rubber Surrounds Hardening With Age PB2 Multi-Way 76 26th October 2017 12:06 AM
18W/8542 - Rubber Surrounds - 14 ohm. $85/pr. nodiak Swap Meet 3 4th August 2009 04:05 PM
porous and hardened Seas rubber surrounds capslock Multi-Way 12 14th November 2005 04:46 PM
replacing rubber surrounds with foam Zymrgy Multi-Way 2 6th January 2004 10:33 PM
