I was at Ikea the other day and I saw a "SEKIN" flat-bottom wooden bowl.
www.ikea.com/au/en/catalog/categories/rooms/dining/10584/
I had a thought that if I cut a hole in its base, I could mount a small FR driver, using the bowl as a sort of basic horn. Add to that a small cabinet of appropriate volume behind to support it.
Now I know that the taper is unlikely to be anything acoustically correct, but I still think it could be the basis for a fun project. Perhaps use the small, circular-frame HiVi FR driver. Paint the unit a wild colour. Enjoy.
Has anyone made speakers from such found objects?
Pictures anyone?
cheers
Doug
Pictures anyone?
cheers
Doug
What I would do is coat the inside of the Blanda Blank with a tar-like damping layer up to maybe 1" from the rim, then weld two of them together to form a spherical enclosure.
Heck, if you didn't mind the aesthetics of it, you could weld two bare bowls together, slap on a damping layer, and then fit another two bowls on top for your own constrained layer damping.
I had in mind using the bowl I originally suggested because it had a flat bottom that would (a) be easy to cut out (come from the back with a hole saw); and (b) be easier in which to mount a driver.
... but hey, whatever!
Keep the original ideas coming.
Further: you could* mount a very small super-tweeter coaxially (on a strut), along the lines of the Hammer Dynamics idea. How about the Dayton ND20FB-4?
* This could be over-egging the pudding!
Doug
Doug
454Casull said:What I would do is coat the inside of the Blanda Blank with a tar-like damping layer up to maybe 1" from the rim, then weld two of them together to form a spherical enclosure.
http://www.diyaudio.com/forums/showthread.php?postid=991882#post991882
dave
IKEA seems to be an endless source of items that can be misused for speaker projects:
http://f24.parsimony.net/forum56884/messages/15430.htm
http://www.lautsprechershop.de/hifi/index.htm?/hifi/ct226.htm
Charles
Charles
- Speakers constructed using unusual items
