And this one:
v-bro said:I like this one:An externally hosted image should be here but it was not working when we last tested it.....
how big is the woofer?
In fact given that OB speakers need big woofers it would be nice to know what the size of the woofer/ baffle is for all the speakers shown just to have some reference.
V-bro I think we have the same tastes I love the look of all the speakers you posted.I'm thinking of something along the lines of the Jamo but using a 15" or 12" dual concentric for midrange and tweet duties.What woofers for 2x15" bass do you guys recommend.Prefer cast baskets.I am thinking about the Dayton rs15".
http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=295-468
v-bro said:It's a Visaton BGS40 18" woofer....
Design is Visaton 'Nobox'
The other one is a DIY design from a dutch audio forum, it's more or less a Jamo clone using very cheap drivers.....(also >40cm/18")
Uhm correction, I think 40cm is in fact 15"....
v-bro said:Hi Lazenna, I think a great choice!
Don't let anybody tell you they aren't!
1. what makes a woofer a good choice for dipole? I mean what do we look for? Qms? Qts? Fs? Any guidelines?
2. That Dayton woofer looks well made but how ouwld it compare to old favs like the NHT1259, Bhrama, Shiva, Tumult or any of the drivers from Eminence (Kappa 15), Selenium (SLF 15), or even pro drivers like the JBL 2235 or Peavey low rider/pro rider subs.
I think if there's enough surface you don't need optimal Q. As long as you have suffiecient hub and surface anything will work, I think preferrably high Qms and Qes.
Allthoug my 'pro' seventies JBL 2220A have very low Qts and work quite nicely in a medium sized room and pretty large baffle (with sides) and the baffle placed in contact with the floor.
Can a maths expert tell us what happens to Qts and spl figures if we change a cone with another one with knowm mass , surface area and (expected ) resonance frequency ?
If you ask why , it's to guess what will happen if we graft a bigger cone on to a smaller frame. Say an 18 inch cone on to a 12 inch frame with various mods to the frame.
Qts should go up and Fs should fall , possibly Qms should go down. Sensitivity would suffer most I think.
Outlandish ... yes ! The web is full of far more outlandish things !
Trying to narrow down my search for bass drivers going by experience or specs which would seem to be better? Ficar audio SSD18
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.88 | 4.96
Qes: .75 | .69
Qts: .65 | .61
Mms: 296g | 308g
Cms: 0.14mm/N | 0.14mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 285 l | 285 l
Spl: 89.4dB 1W/1m | 89.6dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: N/A cuft
Ported box: 6-10 cuft @ 33Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.500”
Displacement: 0.22cuft
Product code: 01918
Price: $ 239.00
*shipping is included
Power Handling: 800 watts RMS
Sensitivity: 89db (2.83 volts)
Impedance: 4 Ohm Nominal (SVC)
Dimensions
Outside Diameter: 46.2cm (18 3/16")
Mounting Diameter: 42.4cm (16 11/16")
Depth: 24.8cm (9 3/4")
Recommended Box Sizes
Sealed: 130 litres (4.6 cu. ft.)
Ported: 200 litres (7 cu. ft.) 19Hz tuning
EBS: 350 litres (12.4 cu. ft.) 15Hz tuning
Mach5 audio IXL-18.4
T/S Parameters
Fs = 17.7 Hz
Re = 3.4 Ohms
Qes = 0.39
Qms = 5.59
Qts = 0.37
Mms = 434.3 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
VAS = 274.1 litres
Sd = 1029.2 cm2
Xmax = 22 mm
Cone Diameter = 36.2 cm
$210.00
DUAL 1 | DUAL 2
Qms: 4.88 | 4.96
Qes: .75 | .69
Qts: .65 | .61
Mms: 296g | 308g
Vas: 285 l | 285 l
Xmax: 21mm
Rms: 800W
Sub OD: 18.500”
Cut ID: 16.750”
Product code: 01918
Price: $ 239.00
Dimensions
T/S Parameters
Fs = 17.7 Hz
Re = 3.4 Ohms
Qes = 0.39
Qms = 5.59
Qts = 0.37
Mms = 434.3 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
VAS = 274.1 litres
Sd = 1029.2 cm2
Xmax = 22 mm
$210.00
What about these Ciare 18" model 18.00NdW1 price** $210.00
weight 6.3 Kg vc size 100mm
size 18" Fs 29hz
power handling 500W (AES) Bl (Wb/m) 24.85
Vas (M3) 0.29643 Sd(M2) .115209
SPL 1w1m 100.5dB Qms 12.36
Xmax 7mm* Qes 0.32
Frequency 30hz-1khz Qts 0.31
magnetic induction (T) 1.2
size 18" Fs 29hz
Xmax 7mm* Qes 0.32
The 18.00ndw1 has a pretty nasty peak between 1 and 2 Khz. This is not a very big problem, but you can't get away with a simple 6db/oct filter....to say the least....
Furthermore they traded excursion for sensitivity, which is not a bad thing given the fact the woofer is BIG. The low resonance frequency comes in very nice.
Conclusion: It can work, but it needs a bit more effort....
Here is an extreme dipole. I've no experience with ob but will have in the future. Like the bass from ob!
http://www.rauna.com/slides/speakerwalljpg.html
It looks like the designer frequently kills mosquitos with a bazooka sure it will rock the planet, but I could think of a few possible or theoretical flaws there...
By the way with the way they're place they're hardly OB, they rather use the corners of the room as enclosure...
- Discussion split from pictures
