best PURE midrange (400hz-->)
Old 23rd May 2007, 11:06 AM   #41
CONVERGENCE is offline CONVERGENCE  Canada
CONVERGENCE's Avatar
For mid highs from 300HZ to 7000HZ :Altec (GPA) 390 driver.
http://www.greatplainsaudio.com/downloads/390series.pdf
For horn the Mr 94B range starts at 300HZ.
Old 24th May 2007, 02:59 AM   #42
rick57 is offline rick57
Id imagine those Great Plains drivers also would be very good. Stage 2 of my system will be compression drivers in home built constant directivity horns, I have the drivers for whenever I get to that.
Does anyone have experience with both PHL and JBL mids?
Old 18th July 2007, 04:14 AM   #43
Daveis is offline Daveis  United States
I've been intrigued by these. Apparently, ex-Altec folks still making vintage sounding new compression drivers?
I've been impressed with the sound of compression drivers more and more recently. They can sound quite good, but I wonder if they measure as good as cone drivers when used under say 90db at listening distance...
Old 18th July 2007, 08:33 AM   #44
el`Ol is offline el`Ol  Germany
I find the compression midrange in the Martion Orgon had the best midrange at the Highend show in Munich this year. By the way, what does the GPA cost, and would this be an alternative?
http://cgi.ebay.de/ws/eBayISAPI.dll?...1295&rd=1&rd=1
Old 11th August 2007, 05:08 PM   #45
tade is offline tade  United States
Send a message via AIM to tade
I plan on using a conically loaded eminence alpha 6 for my midrange. There is also a website a gentleman has made detailing some excellent phase plugs for this driver. He claimed a response from 300-4000hz which sounds very useful to me. These drivers sound quite fine on their own and I am excited to build a horn for them. I also plan on running them open backed to avoid as many resonances as possible.
This sounds to me like a very good midrange solution.
Good luck!
Old 11th August 2007, 06:01 PM   #46
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
After finally hooking up the big horns with the rebuilt drivers, I must add the Altec 1803 horn with the 8 ohm 288 driver as my entry.
500 Hz and up.
Old 11th August 2007, 07:34 PM   #47
Decker is offline Decker  United States
The best midrange that I have heard in my home comes from a pair of Altec 414's from GPA.
Old 11th August 2007, 08:27 PM   #48
Brett is offline Brett
Brett's Avatar
Many of the 18Sound drivers look good. The 8M400 is one I'd like to try.
Old 12th August 2007, 02:35 PM   #49
Magnetar is offline Magnetar  United States
Banned
Default RCF L8LS800
a pair of these a side looks good out to 1.2 to 2k in mtm
Any experience with these for hifi midrange?
Old 21st July 2019, 11:35 AM   #50
Scott L is offline Scott L  United States
Default JBL ?
How about the JBL 2012H, say from 300hz, up to 1.2K ?
best PURE midrange (400hz-->)Hide this!Advertise here!
Stereo Lab 400hz 1" horns winslow Swap Meet 14 21st July 2009 10:40 AM
pure midrange W18E or PR170MO on open baffle? thadman Multi-Way 20 19th March 2009 06:31 PM
Hey Dave hows the FF85K OB at 400hz.....? speakrsrfun Full Range 37 27th January 2009 03:46 PM
Is the Peerless SLS263 (10") clean up to ~400Hz? Virtalahde Multi-Way 5 1st July 2006 09:35 PM
Copyright ©1999-2019 diyAudio
