For mid highs from 300HZ to 7000HZ :Altec (GPA) 390 driver.
http://www.greatplainsaudio.com/downloads/390series.pdf
For horn the Mr 94B range starts at 300HZ.
CONVERGENCE said:For mid highs from 300HZ to 7000HZ :Altec (GPA) 390 driver.
I've been intrigued by these. Apparently, ex-Altec folks still making vintage sounding new compression drivers?
I've been impressed with the sound of compression drivers more and more recently. They can sound quite good, but I wonder if they measure as good as cone drivers when used under say 90db at listening distance...
I find the compression midrange in the Martion Orgon had the best midrange at the Highend show in Munich this year. By the way, what does the GPA cost, and would this be an alternative?
http://cgi.ebay.de/ws/eBayISAPI.dll...MEWA:IT&viewitem=&item=190128781295&rd=1&rd=1
I plan on using a conically loaded eminence alpha 6 for my midrange. There is also a website a gentleman has made detailing some excellent phase plugs for this driver. He claimed a response from 300-4000hz which sounds very useful to me. These drivers sound quite fine on their own and I am excited to build a horn for them. I also plan on running them open backed to avoid as many resonances as possible.
This sounds to me like a very good midrange solution.
Good luck!
Good luck!
RCF L8LS800
a pair of these a side looks good out to 1.2 to 2k in mtm
Any experience with these for hifi midrange?
Brett said:Many of the 18Sound drivers look good. The 8M400 is one I'd like to try.
- best PURE midrange (400hz-->)
