Instruments and Amps Everything that makes music, Especially including instrument amps.
peavey cs800 power amplifier
Old 27th November 2002, 08:13 AM   #1
bong is offline bong
Send a message via AIM to bong Send a message via Yahoo to bong
Default peavey cs800 power amplifier
dear all,
recently i'm fixing peavey cs 800 power amplifier(800 watts) with low sensitivity response (seem this PA not giving all power that he had) if i compared with the same source from mixer console with other poer amplifier like interM1000 (1000 watts) this peavey sond much smaller than that.
What i did is, I try changed some of the op amp in the input stage
(RA......? i forgot the type) with TL 072, its work but in different character than Ra...? and checking all the passive components and the transistors, seem everything okay? (oh yaa, i changed some diode inside the output heatshink with 1n4003 because some of them are leak)
and the other IC is 7487...?( i'm forget the last 3 number) with TL 072 but its not work (the protect led lights), my question is:
.what wrong with this Power amplifier?
.what is the equivalent of 7487..? in this PA? is it something wrong with this IC's?
thanks in advanced,
bonie bong
Old 27th November 2002, 01:09 PM   #2
djk is offline djk
R.I.P
djk's Avatar
"recently i'm fixing peavey cs 800 power amplifier(800 watts) with low sensitivity response (seem this PA not giving all power that he had) if i compared with the same source from mixer console with other poer amplifier like interM1000 (1000 watts) this peavey sond much smaller than that."
The input sensitivity of the amplifiers (gain) is different, don't mess with it.
".what wrong with this Power amplifier?"
Nothing, the gain is different.
"what is the equivalent of 7487..?"
That is the date code, not the part number. Put the original part back in and hope it works.
"in this PA? is it something wrong with this IC's?"
There was nothing wrong with the original IC. Put the original back in and hope it works. If it doesn't work, take it to a qualified electronics technician. Tell him you stuck in a TL072 where the NE5534 should have been. There is also a 555 timer in the DDT limiter circuit.
Either turn down the input gain on the interM1000 until it matches the CS800 or add a line amplifier to the input of the Peavey.
Old 28th November 2002, 08:06 AM   #3
Thanks for your information.
peavey cs800 power amplifierHide this!Advertise here!
Peavey pv2000 power amp e_c_mccollum Instruments and Amps 6 18th January 2010 04:18 AM
Peavey cs800 schematic aits Instruments and Amps 9 27th October 2008 09:53 AM
Sick Peavey IPS800 amplifier Burnedfingers Instruments and Amps 1 24th April 2008 12:42 PM
PV CS800 clip LED's & power switch don't light javey Solid State 2 3rd May 2005 03:31 AM
Peavey CS800 power transistors smokinleroy Parts 1 6th April 2004 01:45 AM
Copyright ©1999-2019 diyAudio
