Instruments and Amps Everything that makes music, Especially including instrument amps.
Advice on cab finish?
Thread Tools
Old 21st October 2021, 12:51 AM   #11
phase is online now phase  United States
I would be cautious mixing brands of glue, they can have differences in their solvents that can lead to bad results.
This was a mock-up built for the purpose of gaining a contract that has so far realized $195 billion in revenue.
I was chosen to design and build this in a very short time, and that adhesive #*~+ up was the only hitch.
After my experience, I contacted 3M, who’s chemists told me to basically never to mix anything else with their specific adhesive that I was using. So unless you know for certain…
Old 21st October 2021, 03:17 AM   #12
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by fabricadetabaco View Post
Yes glue is a topic of its own I guess. Do you know any such forums? I have been googling quite a bit but struggle to find anything sensible. Talk-bass had some.
1) state your Country
Suggestions vary A LOT depending on where you are.
2) use solvent based contact cement, the kind you buy in a 4 liter can and apply with a fine toothed spatula/notched trowel.
You can use a medium sized short hard bristle brush to apply it to inside corners , along internal mounting cleats, etc. where trowel is impractical, but immediately after use wet it with solvent.
I keep my brushes inside cylindrical cookie tins with 1 cm or two of solvent at the bottom, metal is best barrier against evaporation, plastic is porous to Toluene/Xylene.
Forget water/"green"/"ecological" type adhesives.
Follow manufacturer´s instructions,including timing, ambient temperature and humidity, ventilated space but avoid drafts and sunlight, etc.
3) it´s a good idea to also buy a small can (250-500 cc) of factory recommended cement solvent to clean tools, spills, etc.
4) I suggest this brand, unless unavailable in your Country,Mother Company is British (EVO STIK):
Small World, I am NOW tolexing 2 Keyboard amplifier cabinets, go figure.
Over 14000 so far.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 21st October 2021, 10:37 AM   #13
MikePP is offline MikePP
Over 14000 so far.
That's not bad out of one tin
Old 21st October 2021, 08:07 PM   #14
fabricadetabaco is offline fabricadetabaco
Thanks for all the input here, it seems I just need to find the faux leather and follow instructions with glue, read read read. I’ll check all those links. Thanks again.
Old 22nd October 2021, 12:55 PM   #15
JMFahey's Avatar
You should have seen the size of the BRUSH!
  Reply to this post
Advice on cab finish?Hide this!Advertise here!
Thread Tools
Could the SA-310 bass cab be used for a bass and guitar cab? JThompson56 Instruments and Amps 14 17th August 2012 09:50 PM
Thiele guitar cab vs. ported guitar cab qingcong Multi-Way 2 9th January 2011 04:32 PM
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 11:46 AM
Vintage Full range- Need some cab advice waam68 Full Range 7 19th August 2008 10:30 PM
Advice on cab design for Fostex FE206 Analogue_Adam Multi-Way 0 6th November 2005 10:02 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
