Instruments and Amps Everything that makes music, Especially including instrument amps.
Oscillating Bipolar Guitar Amp
Thread Tools
Old 26th July 2021, 06:02 AM   #21
Inch-o is offline Inch-o  Slovenia
Just an intermezzo question... Where are you attaching your oscilloscope GND clip? I hope not to the "-" output terminal.
Also when you insert a jack into the effects rtn, do please short the "hot" and gnd. In this way you will be sure no strange "things" are being picked up by the amp.
Good luck!
Old 26th July 2021, 08:45 AM   #22
turk 182 is offline turk 182  Canada
well that's even more confusing ....so what components did you remove, or how did you isolate the amp section? was it left open ended ?
Old 26th July 2021, 11:02 AM   #23
Telnet100 is offline Telnet100  New Zealand
Hello
First Answer: The Scope was grounded to the System Ground on the Main PC Board, adjacent to where the Reverb Tank is grounded. I hear what You are saying re the Hot and ground, I will try shorting these two absolutely.
Second Answer: I had Replaced, in this order:1; The Main 4700uF Filter Caps; 2; the Bypass Electros on the Opamp supply leads; 3; All of the other Series Electros in the feedback loops, and, 4; lastly, the two Output Devices, which I have been assured have come from Original Manufacturers. The Amp Outputs were connected to my 2 x 8 Ohm Workshop Test Speakers.
Thanks for all the help -- I will keep you informed on progress.
Old 26th July 2021, 04:14 PM   #24
Hi again,
Check the components(resistors & caps) in the three NFB(negative feedback loop)
1. NFB directly around the opamp(680k & 3.9k + 2.2u to gnd)
2. DC offset(servo) - done from the output through two 27k in series + 2.2u cap to
gnd(now that I think about it, the 2.2u should represent a dead short to gnd to the hf oscillations signal)
3. NFB from the .47ohm resistor back to the opamp(3.9k + 4.7u to gnd)
Check the resistors by desoldering at least one pin, so not to measure the complex circuit resistances.
Also check the two 47u caps tied to the opamp supply pins and the 220ohm resistor going to the output. This circuit is a boot-strap circuit to the opamp.
As somebody else here suggested, be sure to eliminate the possibility of the oscillations entering the power amp from the preamp/preamp psu...
Check for any interrupted gnd tracks(just as a tip: thin tracks running between IC pins and alike)
Good luck!
  Reply to this post
Oscillating Bipolar Guitar AmpHide this!Advertise here!
Thread Tools
Difference between self oscillating and non-self oscillating D-amp. sildex Class D 36 4th August 2010 03:30 PM
Self Oscillating (Oscillating Calculations) Help! Reactance Class D 7 12th March 2010 07:37 PM
DIY tube guitar amp oscillating, please help! frickecello Instruments and Amps 13 3rd August 2009 04:10 AM
oscillating...always oscillating WoulYaShassu Solid State 30 9th April 2004 05:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
