Had trouble finding the detailed spec sheets, here and index, click on the part number,
then click on the .pdf link:
Tube Guitar Amplifier - Output Transformers (1750 Series) - Hammond Mfg.
That is for 1750 and 1760 part numbers.
This is the much more detailed .pdf that is available, with winding resistance, inductance
and measurements:
https://www.hammfg.com/files/parts/pdf/1750K.pdf
But I think the above data sheet has an error with 12.5H as the primary inductance,
since most of the 4K primaries are 3.5 to 4H.
and measurements:
The catalogue of all hammond transformers could help: https://www.hammfg.com/files/literature/5c.pdf but it seems information is poor too.
Not sure what you are saying here about '4K primaries are 3.5 to 4H' ??But I think the above data sheet has an error with 12.5H as the primary inductance, since most of the 4K primaries are 3.5 to 4H.
Are you saying you measured the P-P inductance of 50W OPT's with 4kohmPP nominal primary ratings using a 1Vrms 1kHz signal with no DC?
