Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Instruments and Amps Everything that makes music, Especially including instrument amps. |
Thread Tools |
#131 | ||
#132 |
Now that the bias is stable, what is the bias divider? .. both circuit and resulting voltage.
Disappointing that the distortion is still present -- would'o thunked/hoped that fixed itself with the bias fix. You do still have room for a couple hundred more uA's of battery draw, right? (currently ~750uA if my arithmetic is correct) Regards Last edited by Rick PA Stadel; 18th January 2021 at 09:15 PM. |
#133 | |||
#134 |
Ok ok ok, now I had some more time to fiddle around with the preamp, trying every combination possible, even running the bass passive which actually made me figure something is off and that led to new discovery. I found the root of the distortion. It's not the preamp, it's the load from the other preamp, but while it's only unpowered and inputs are connected together on both preamps. You had a really good point about it Rick, I just wanted to deal with it at the end but there it is! But when both preamps are powered at all times, and only outputs are being switched, both preamps sound flawless!
I don't know why for the hell of me I didn't power the other preamp at least once while working on this one. Probably cause I needed a second cable plugged in in the second jack on the bass used for testing and I guess that's why it didn't occur to me.... Both preamps together draw about 1.84mA, which actually seems great considering it's two high performing preamps. I can definitely live with powering them both all the time at that current feed and switching the output only.. haha. This also simplifies switching between the two drastically. However, will need to connect everything together to have my final thoughts if absolutely everything is working as it should when everything is in the cavity. This is still wires everywhere, some components still hanging on wires etc. So, we have the diode and 1M resistor bias now with no cap. Are we putting in a cap of some value? 10-47uF? I can easy go with 47 as I know I should have those on hand in the correct size, will need to recheck for 10uF. Rick, I can't explain how thankful I am to you!!! |
#135 |
I'll post some photos of the finished products when I get there
#136 |
You're welcome! It's been a fun run! Plus, that ax is absolutely GORGEOUS!
![]() Take your time and work carefully, but I'm anxious to see the pics. If you have something still smaller for the bias divider filter, would be fine. Anything bigger than about 0,1 to 1uF won't give any additional filtering. Good catch on the unpowered preamp input loading .. I had kinda forgotten about that! ![]() Again, mondo congrats! Cheers |
#137 |
Congrats to you for being able to provide extraordinary help remotely! Thanks again and
![]() OK, so I can go for the cap as low as 0.1-1uF. I think I have 1uF, will need to check the voltage rating on it, it may fit. And to put the rest of components on the pcb instead of hanging on wires. I'll report how it goes, now I'm eager to finish it, put it inside the cavity with the other preamp and wire everything as a final complete product. Since they'll be both powered simultaneously now, I'll have one line empty on the DPDT switch, I'll use it to break the connection on the input as well. |
#138 |
With the bias divider using a diode, the voltage can't exceed about 0,6V -- no need to check its voltage rating.
You may have a worse pop problem by switching the inputs, too. As long as both preamps are powered, the loading caused by the input of the switched-off preamp should be pretty minimal. You COULD wire both sides in parallel. Won't make a lick of difference today, tomorrow, next week, or next month, etc. But someday, one side may get noisy before the other does. Regards |
#139 |
Thanks for the input. I used 4.7uF, it's what I had as a spare capacity. When I was getting the components I got the very long life hybrid polymer caps with ultra low ESR to extend the life span of the preamp as much as possible. Works perfectly even though it has plenty of excess capacity.
Wired everything, switching both input and output. The only common thing the preamps share is the power supply at the same time. Current draw for both is 1.76mA, slightly better then my rough estimation. There is literally zero clicking or popping noise when switching between the two. This solution works great and doesn't require any additional components. I couldn't be more happy with this solution and how it performs for both. Give me a couple of days I'll post pics of both. Would post sound samples but don't have any recording gear unless I figure something out in spare time. |
#140 |
![]() Excellent! |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
bass guitar preamp with eq, what bands are best? | garybdmd | Instruments and Amps | 14 | 19th March 2020 11:01 AM |
bass guitar preamp | billr | Instruments and Amps | 19 | 26th May 2012 04:36 PM |
Preamp for bass guitar | destroy2 | Instruments and Amps | 1 | 21st June 2011 03:30 PM |
Bass guitar preamp | zafira1981 | Instruments and Amps | 33 | 26th January 2010 03:02 AM |
Hybrid bass/guitar preamp | Mikael Abdellah | Instruments and Amps | 10 | 16th February 2007 11:16 AM |
New To Site? | Need Help? |
