Hi, the hum balance rotary switch on my amp needs to be replaced. The spec listed on the Photofact is 200 ohm's, and the switch is dual gang. I'm having no luck finding such a switch. I've looked at Digikey, Mouser, Antique Radio Supply, and have performed multiple web searches with no luck. I've found single gang 50 ohm and 100 ohm for guitar amps. Any insight as to where I can find a replacement switch? Thanks.
The amp is a Bell 3030. First time posting pictures, so my apologies if what I tried doesn't work.
I noticed my post was moved to what appears to be mostly guitar amps when I originally posted in the tube amp section. Not understanding why that happened.
- Tubes / Valves
- Hum Balance Switch for Bell 3030
