Instruments and Amps Everything that makes music, Especially including instrument amps.
Diy Strat Pickups Coil Tap Question
Old 22nd May 2020, 01:58 PM   #21
Gnobuddy is online now Gnobuddy  Canada
Originally Posted by Tubelab_com View Post
...RF duplexers...Tesla coils...
Thanks for that - I know nothing about RF duplexers!
These effects may not be audible in a guitar pickup...
This is what I suspect, based on the fact that the distributed stray capacitance of the pickup winding only seems to have an effect on frequencies above the range of the electric guitar and it's speaker.
The thick brass(?) housing around the OEM humbucker in one of my South Korean guitars, on the other hand, seems to have a very audible effect. One massive shorted turn...
Here is a thread in which some people say they can hear a difference between a copper-plated nickel humbucker cover, and one that's not plated: Nickel Pickup Cover Material
-Gnobuddy
Old 22nd May 2020, 02:52 PM   #22
bucks bunny is offline bucks bunny  Germany
I experienced the effect of metall plated pickups sounding dull with the second electric guitar in my life, a German Höfner.
Old 22nd May 2020, 02:55 PM   #23
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I have never tried to wind a conventional guitar pickup. Most of my experiments have been related to individual pickup coils per string, and have not been too successful, but I did get some more material for further experimentation down the road.
I went off on a photoelectric pickup tangent several years ago, with promising results......that all ended with the advent, and subsequent popularity of LED lighting. Much of that stuff is filled with high frequency modulation from the cheap, poorly filtered SMPS based power supplies.
Besides the usual MIDI aspects of hex pickups, there is still one aspect of the electric guitar world that remains unexplored. We all have heard the muddy ugly sound that results from playing full six string chords through a highly distorted amp. This comes from the non musically related tones created by the IMD products generated when two or more simultaneous signals are stuffed through a non linear device, like an amp turned up to 11.
It should be possible to route the output of each string through it's own individual amp, and speaker. Each amp could have it's own controls and speaker tailored to the frequency range it produces.
Many years ago I cut a couple single coil pickups up, and rewound them to be two separate single coil pickups each fed to their own amp. This was a step in the right direction, and afforded far more tone variations than the usual setup, but IMD was still a problem when fully cranked. One amp per string would generate zero IMD in theory since it only sees one tone at a time.
I have a piezoelectric hex pickup and some experiments with it show promise, but I prefer the sound of magnetics, or a blend of the two.
Note that some of the cheap little PC "beep" speakers are actually magnetic, and do make a fair single string pickup, albeit with a rather low output, requiring an opamp in the guitar, as does the piezo pickup, due to it's high output impedance.
I imagine a full hexaphonic system would have so many controls (like a modular synth) that it would be hard to master, and harder to play live without some kind of preset store and recall setup.
This was the reason behind my diversion into solid state guitar amp stuff in the 1990's using some SPI controllable tone, volume, and graphic EQ chips....neat idea, but it didn't catch on and the chips have since gone extinct.
Tubelab, I blow stuff up so that you don't have to.
Old 22nd May 2020, 05:10 PM   #24
In the 1990s I experimented with an optical pickup too (something I was already using in grad school to measure vibrations of a mirror suspended in a vacuum tank). But I had issues with shot noise, as well as fluorescent room-lighting flicker at 120 Hz. String-bending on the guitar was a problem too, as full-note bends would push a string entirely out of the light beam. So I gave up on the optical pickup idea.
I tried a brief experiment with a home-brew six-coil pickup in the late 1980s. I had no money at all, so I used a 4069 CMOS hex inverter for my six-channel preamp, biasing all the inverters into linear operation with a resistor connected from input to output. It worked, but badly, with lots of hiss. I never followed up that idea later.
I have a Boss DA-2 distortion pedal. One of the advertised features is that you can play heavily distorted chords and retain some clarity. It's a digital pedal, and I think it uses DSP to, in effect, separate out each of the six guitar notes (probably with an FFT), distort each one individually, and put them back together.
Craig Anderton's "Quadrafuzz" used a similar idea, separating the guitar signal into four frequency bands with analogue bandpass filters, then distorting each band individually before recombining the signals: PAiA: Quadrafuzz Design Analysis by Craig Anderton
-Gnobuddy
Old 22nd May 2020, 10:22 PM   #25
I made a simple led / photocell setup which sucked for the same reason you mentioned, especially 60 and 120 Hz pickup. All of it was mounted near the bridge, and covered with a large bridge cover from an old guitar.
The next step was infrared led / sensor pair from TV remote control systems, better, but not perfect.
The next step was using a high frequency square wave lighting two LED's out of phase, and synchronously chopping and alternately reversing the sensor output such that low frequency stuff cancelled out. That worked pretty good until high frequency light noise from LED lights appeared.
I did not know that PAiA was still around. My first "modular synth" was a PAiA 2720 kit with shirt buttons for keys back in the early 70's. I got a keyboard out of a dead organ in the trash dump and wired it up. Neat toy, but wouldn't stay in tune for very long.
For now I'll play some more with the magnetic stuff. I need some good weather for some wood working time......I got another Dumm Blonde idea for a guitar with swappable / removable pickups and electronics. It would make experiments like these far easier and I wouldn't need to toss the guitar body when I change my mind, add or remove some controls, or something just doesn't work.
I learned it by watching this guy:
YouTube
Old 23rd May 2020, 04:43 AM   #26
Cool trick! Reminds me of the optical choppers and lock-in amplifiers I used to work with.
Amazing, isn't it? These days even this this diyAudio sub-forum seems almost dead, and somehow PAiA soldiers on. My hat is off to the people running it!
...a guitar with swappable / removable pickups and electronics...
Cool idea!
You might like this version of that concept - pickups that rotate in and out of place! YouTube
The crazy internal mechanical linkage (to the slide switches) looks too complex to home-brew well, but the rotating cylinder carrying the pickups seems do-able; flipping the pickup cylinder over with a finger would still be pretty quick and easy.
Way back in 2014 or so, Fender tried a much simpler version of the "quick sound change" idea - they sold a Stratocaster with separate "personality cards" that you could swap in or out to instantly re-wire the existing pickups, switches, and knobs. I don't think the idea caught on, but perhaps it might inspire you: YouTube
-Gnobuddy
Old 23rd May 2020, 12:34 PM   #27
I borrowed the idea from some Hewlett Packard and Boonton RF measuring test equipment. The Boonton measured millivolts of RF signals in the presence of large 60 HZ noise in an industrial setting. It used a mechanical chopper. I was changing those choppers at a 1 to 3 a month rate for over $100 each in the 1970's since the equipment ran 24/7.
The HP RF power meter did pretty much the same thing with some CMOS switches. One of my tasks was to copy the HP circuit, put it on a little board and use it in the Boonton to replace the mechanical chopper.
The Gyrock system is probably beyond my construction skill level, and I am more interested in experimenting with active electronics in the guitar than the pickups. Previously I had to remove all the strings to take the pick guard out which had the electronics on it. The cycle time from playing, disassembly, reassembly, to playing again was a couple hours if I didn't screw anything up, or lose my patience.
I am going to try a mount from the back approach for faster swaps. Since many of my dumb guitar ideas wind up in the trash, it will be ugly pine wood. It will serve as a test bed to try out dumb ideas that have been stuck in my brain since the 60's and 70's.
Here is another that I have experimented with off an on since my first day at Motorola in 1973 when I first met the Motorola Vibrasender and Vibrasponder (essentially the same thing).
Here are two pictures of a device that Motorola used to detect or generate fixed audio tones used for electronic signaling in two way radios. Larger versions were used back into the late 1930's. These are from the last generation in the 60's and 70's before an opamp based chip replaced them.
Inside you see a mechanical vibrating reed with two tiny magnets glued on the end that moves. There are two coils, one near each magnet. To me this looked just like the reed used in a Wurlitzer piano, so I spent some time playing with these and expanding on that idea.
In "sponder" mode an audio signal is sent to one coil, and the other coil goes to a level detector. When the audio signal is at the "wrong" frequency, nothing happens. When the input frequency is very close to the resonant frequency of the reed, it will vibrate, and the moving magnet will induce a voltage in the other coil, tripping the level detector.
In "sender" mode there is no level detector. The signal from the output coil is amplified and fed back to the input coil creating an oscillator, to generate the tone.
There was a bank of Vibrasenders in the dispatchers office, and a unique Vibrasponder in each taxi's radio so one radio could be individually called.
So the Dumm Blonde One wires one of these to a guitar cord and smacks it with a drum stick, and music was made. Then he learns how to take them apart and "tune" them to musical note frequencies with some well placed solder. He might have spent days experimenting with the coils out of these things and a guitar string stretched out on a 2X4. Maybe even mounted a few inside a kids toy piano.
The Vibrasponders came in two flavors, most were used in "subaudible" (low frequency) signaling, such that signaling and voice could be sent at the same time. The lowest available frequency was 67 Hz and the highest was around 200 Hz. The coils from these did not respond well to the higher notes on a guitar string. There was a much smaller Vibrasponder with frequencies from 1Khz to 2.something Khz used in pagers, but their tiny internals were too easily damaged for many successful experiments.
Once the idea was planted, it didn't take much for me to swap out the Vibrasponder coils for guitar pickups. Yes, it's possible to take two pickups and a healthy opamp and make a guitar string play itself. Hours of fascination ensued from 6 strings mounted on a 2X4, tuned to an open E chord, and a Coricidin bottle.
This the principle behind the "infinite sustain" systems seen today. My experiments at the time (early 70's) were done with a pair of plastic housed unshielded pickups from an old Hagstrom. I still have them. There was a very narrow range of feedback gain where a self sustaining string happened, and before utter mayhem broke out. This could be improved with shielding between the two pickups. Things might have worked out better with grounded metal cased pickups. Attempting to make all 6 strings play nice through two pickups creates all sorts of unwanted tones where harmonics of the bass strings tend to excite higher strings.
I want to explore a separate sustainer for each string, hence the hex pickups.
The popular Ebow works the same way with two metal rails on either side of the target string, with a coil mounted on each rail.
Old 27th May 2020, 12:24 PM   #28
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by bucks bunny View Post
John Mayer is one of my guitar gods as well. What you perceive as John Mayer sound is
95% John Mayer
5% guitar, pickup, strings - the hole rig
So why waste your time with the most unimportant area?
Couldn't agree more!
Another example: If you didn't know, would you have guessed that Jimmy Page recorded any guitar track (with the exception of the acoustic ones and the lap steel, of course) for the 1st Led Zeppelin album using a simple Telecaster that he has been given by Jeff Beck previously?
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Old 27th May 2020, 05:17 PM   #29
mondogenerator is online now mondogenerator  England
mondogenerator's Avatar
@ Gnobuddy
I have an possible explanation for your observations when using a brass pick up cover.
Brass is very good at reducing magnetic flux/inductance (perhaps leakage inductance in particular?)
I guess it acts almost as an air gap does in a transformer core, lower magnetic permeability I think, perhaps then this shifts the flux pattern around the strings.
Sorry for the OT.
I still want to know why I prefer nickel strings over steel, I've tried many strings and always end up coming back to Slinkys, on all my guitars.
String composition has probably just as much influence on tone, though I dont understand why!
Let her rip, tater chip
Old 27th May 2020, 06:15 PM   #30
Originally Posted by mondogenerator View Post
...brass pick up cover...
It's interesting to look at the design of the Filtertron humbucker cover (image attached). The metal right around the pole-pieces is cut away, and there's also a gap cut in the metal so that eddy currents can't flow in a big loop that encloses all six pole-pieces.
Clearly, the designer of the Filtertron was thinking about eddy current losses in the cover more than his counterpart at Gibson did.
-Gnobuddy
Diy Strat Pickups Coil Tap QuestionHide this!Advertise here!
Would strat pickups fit in this ? hitsware Instruments and Amps 8 4th February 2018 01:00 AM
Squier Strat (Japan) schematic... knockbill Instruments and Amps 20 30th December 2015 03:53 PM
Strat pickguard? whatsnext Instruments and Amps 5 2nd November 2010 02:46 AM
looking for some help for modifying a strat Skywalker83 Instruments and Amps 4 2nd November 2010 02:43 AM
magnet+coil pickups, piezo pickups and Roland GK-2 midi, how does the output differ? Puggie Instruments and Amps 1 19th September 2006 07:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
