Instruments and Amps Everything that makes music, Especially including instrument amps.
Fender Frontman 212R (help)
Old 18th March 2020, 12:29 PM   #11
Andre Oliveros is offline Andre Oliveros
Ok, thanks just to be sure because im not familiar with these terms or names,
Opamps = the ICs like the one i measured?
Zeners = the diodes? If so which ones?
Sorry about the question is just i never heard of it, and also when i googled thats what i got, if is not anproblem please confirm or clarify, thanks
Old 18th March 2020, 08:21 PM   #12
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
OK,
Opamps are the ic's, small black multipeed thingies, 8 pins. Labeled U1 to U8.
Zenerdiodes, D57 and D58.
1. Remove the opamps first.
2. Change the zeners.
3. Check the +/- 16V. Should be there.
If all is wel, insert the opamps, one by one. Check each time if you have the +/- 16V.
Do not continue if the 16V drops with,let's say, 0.5V or more.
Then, maybe an electrolitic cap coul be bad. But that's a bit to far to think about.
May the electrons be with you
Old 19th March 2020, 05:33 PM   #13
Thanks a lot, i think this is going to put me in the right track, ill let you know as soon as i can order the parts and change em, thanks a lot pal
Fender Frontman 212R (help)Hide this!Advertise here!
Extract Preamp Section from Fender Frontman 212R 0360 Instruments and Amps 24 19th December 2016 03:53 PM
Fender Frontman 212R distorting even on clean channel. true audio Instruments and Amps 4 4th August 2016 09:05 AM
New Problem with Fender Frontman 212R diynow89 Instruments and Amps 37 3rd May 2015 03:57 PM
Fender Frontman 212R - Extremely Loud Popping Noises.. cloudsound7 Instruments and Amps 3 6th June 2013 06:39 PM
Problem with Fender Frontman 212R amp diynow89 Instruments and Amps 2 18th November 2011 07:41 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
