Instruments and Amps Everything that makes music, Especially including instrument amps.
inline attenuator of dual piezo pickups
Old 10th March 2020, 11:06 PM   #31
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by chicofi View Post
I have a custom "stereo" cable that assuming I got the concept right, means I could have the resistor circuit hidden in the tailpiece of the bass (see attached)
Thanks! Yes it's a humbling instrument along with trumpet, trombone and likely several more instruments I'm not familiar with. But really, all instruments are difficult. some tell you up front and others let you know later as you're deeper in. It's also really hard to stand out as a guitarist - it's a deep instrument!
I've installed a few Piezo's in upright basses and it is certainly very tricky to
get an even natural sounding response.
There are a few options.
- The stereo jack OP with separate feed from each piezo is a good way to go
I don't think using a 1M passive potentiometer level control after each is the
best idea, depending on the OP level, the pot could introduce significant noise
purely due to the high value of resistance (Johnson noise) and the piezo
really wants to see a very high impedance for best sound. IME, an
active buffer fed directly from the piezo will give the best results.
- Another option is to make a dual active buffer + level control in a tiny box
with a single 9V battery. This can be mounted to the Bass with velcro etc.
FWIW, I've usually obtained best results using just 1 piezo and play with
the mounting location. How and where is your Piezo attached to the bass?
This makes a massive difference to the sound.
TCD
inline attenuator of dual piezo pickupsHide this!Advertise here!
Piezo pickups and onboard preamp for Piezo Gene_Johnson Instruments and Amps 2 19th February 2010 12:55 PM
Piezo pickups and onboard preamp for Piezo Gene_Johnson Everything Else 0 15th February 2010 02:47 AM
Piezo pickups Pbassred Instruments and Amps 17 19th April 2008 04:56 PM
Adding Piezo to Magnetic Pickups jkratz Instruments and Amps 12 30th May 2007 09:11 PM
magnet+coil pickups, piezo pickups and Roland GK-2 midi, how does the output differ? Puggie Instruments and Amps 1 19th September 2006 07:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
