Instruments and Amps Everything that makes music, Especially including instrument amps.
Roland JC-120
Roland JC-120
Old 1st March 2020, 07:45 PM   #1
ronjg is offline ronjg
ronjg's Avatar
Default Roland JC-120
I have a Roland JC-120 (serial# 728284) that Has a relatively loud 60Hz buzz through the speakers. Also, no audio. None of the fuses are blown. I need the correct repair manual for that version. Also if anyone has any suggestions on what may be wrong, I'd really appreciate it. I'm thinking rectifier diodes or filter caps. The bridge rectifiers in this version are individual diodes as opposed to a single bridge rectifier brick.
Thanks,
Ron
* edit: Bridge rectifier diodes and Filter caps all test okay.
Old 1st March 2020, 11:16 PM   #2
MAAC0 is offline MAAC0  Portugal
Check rectifier / caps and for loose ground wire / solder pads connections.
No audio mixed with the buzz ?
Schematics from google search attached
Old 2nd March 2020, 12:44 AM   #3
ronjg's Avatar
[QUOTE=MAAC0;6104947]Check rectifier / caps and for loose ground wire / solder pads connections.
Thanks very much for the schematic! I checked all of the rectifier diodes along with the 3300uFd filter caps on the power supply board and they all test okay. There is no audio mixed with the buzz. Also, the buzz does not sound like the hum from a bad ground. I'm thinking it may be the output transistors except from my experience that would cause a fuse to blow and the fuses are all good.
Old 2nd March 2020, 04:35 AM   #4
Enzo is offline Enzo  United States
Fuses don't always blow, check for DC on the speakers. Look at their cones. When you power on do they move one direction and stay there? if so, that is DC. You can also measure with a volt meter.
Roland JC-120Hide this!Advertise here!
Roland SRA 540 Carlosraj Instruments and Amps 3 22nd January 2015 11:40 AM
Roland SPD 8 Carlosraj Instruments and Amps 1 6th July 2014 08:50 PM
Roland SPA-240 IsakAlexander Instruments and Amps 4 2nd June 2014 11:09 AM
mod for roland 405 amp DanTheBluesMan Instruments and Amps 1 10th September 2002 06:39 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
