Instruments and Amps Everything that makes music, Especially including instrument amps.
Crackling sound at high volume
Old 5th March 2020, 01:23 PM   #21
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
A dummy load is a resistive load a speaker is not. +
But I would check first the connection between head and cab, since it happen only with the 8 ohm cabinet I suspect the jack at cabinet to be faulty or simple it vibrates too much.
I had a 2x12 cab with a loose back panel, at high volume a good palm mute would throw the jack out of the socket
Old 5th March 2020, 01:57 PM   #22
RadioOctave is offline RadioOctave
Great idea. I checked through another Mesa Cab, same prob
j
Old 5th March 2020, 05:06 PM   #23
Just spent 20 minutes playing the amp dime'd across the board at 16ohm with zero issues. 8ohms...thats another story.
Could it be the OT?
Old 6th March 2020, 07:27 PM   #24
More testing
-two 8 ohm 4x12 cabs in parallel with amp at 4ohms. crackle.
-one 8 ohm 4x12 cab with an 8 ohm 2x12 with amp at 4 ohms. NO CRACKLE?
The 4x12 is a mesa with 4 v30s. The 2x12 is a peavey 4x12 in stereo, using only one side with sheffield something or others.
This is banana crazy now.
Anyone have any ideas?!
Old 7th March 2020, 09:14 PM   #25
Found it.
Heater wires were too close to chassis causing the parasitic oscillation. I dont know why the chassis would be so susceptible, but raising the heaters 1cm from the chassis eliminated the sound.
Just thought I would close the loop on this.
j
Crackling sound at high volumeHide this!Advertise here!
Sundown NS-1 sound cuts out at high volume - No protect Troy Dionne Car Audio 4 30th April 2017 02:47 PM
Beginner: Crackling and low volume on headphone amp gatekiller Chip Amps 19 2nd December 2011 06:44 AM
lepai ta2020(b) no sound when reching high volume moshemft Class D 2 2nd October 2011 08:54 PM
Valve buffered IGC - volume pot causes DC offset, crackling gaplessophile Chip Amps 29 3rd July 2009 12:02 AM
Crackling at high volume matheprat Chip Amps 13 21st January 2007 07:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
