Instruments and Amps Everything that makes music, Especially including instrument amps.
Hartke HA5500
Hartke HA5500
Old 2nd March 2020, 11:49 AM   #21
Carlosraj is offline Carlosraj  United Kingdom
Originally Posted by turk 182 View Post
eek! don't cut the trace lifting one end of R336 should do the trick!
as to relay operation i don't know(never been this deep into the protection circuit of a Hartke!) i'm hoping it would help determine if the fault is from the amp's operational condition or whether it's with the protection circuit itself.
i've spent a little time looking at the data sheet for the 7317 it seems to be a comparator of sorts and i'm unclear as to how turn on delay is acheived??
have you had a chance to check for oscillations?
Not yet.
Old 2nd March 2020, 12:22 PM   #22
turk 182 is online now turk 182  Canada
are you running/using a DBT on this currently?
Old 2nd March 2020, 12:29 PM   #23
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Ok, now with some numbers we are starting the good path.
As mentioned above, a BEEFY power supply such as the one you have should not drop 7V each rail just from connecting a power amp board, even less if itīs already connected and just output relay clicks in.
A transistor Class AB stage "eats" very little at idle, a few mA, "nothing" compared to full power 10A or so.
BUT you say you messed with the bias trimmer and did NOT check idle current ... worrying.
You might have turned your power amp into a current guzzler which in due time might explain the protection circuit problems.
For now:
1) disconnect load (speakers/resistor/whatever) , work unloaded until we get proper DC values.
2) measure idle current, maybe schematic explains how to or suggests some values.
If none suggested, adjust bias so each power transistor passes between 25mA to 35mA each which should be a reasonable value.
To check current measure voltage drop across each emitter ballast resistor and do the Math.
3) not discarding oscillation as impossible, by any means, but suspect improper DC adjustments could be triggering protection, so get them in line first.
EDIT: what DBT asks.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 2nd March 2020, 12:44 PM   #24
DBT = dim bulb tester or lamp current limiter
Old 3rd March 2020, 10:20 AM   #25
I have put the amp aside first to fix my scope, it is malfunctioning. I will get back once it is done.
Old 5th March 2020, 11:05 AM   #26
For now:
I could not get my scope done, but today I checked all the components, caps diodes, resistors, regulators on the power supply circuit, and they are OK. I noticed some differences on the power amp board, (A) both the thermistors are marked 50K on the schematic, but they are measuring about 15K, (B) R346, the resistor connected to the relay coil is 1.2K on the schematic, but there is a 3.5K resistor on the circuit. (C) Q303 gets very hot, but the other transistors around it are slightly hot. Adjusting VR302 (offset) does not make any voltage difference. Someone has worked on this amp earlier, so I will check to see if all the component values are correct. I have ckecked the zobel components and the components around the protection circuit, they are OK.
Old 19th March 2020, 12:32 PM   #27
get any where on this?
Hartke HA5500Hide this!Advertise here!
Hartke LH500 Carlosraj Instruments and Amps 4 23rd June 2017 08:36 AM
Hartke LH500 famousmockingbird Instruments and Amps 11 9th January 2017 05:26 AM
Hartke gt100 tr69 Solid State 3 27th August 2012 09:51 AM
8 or 4 ohm amp to 4 ohm cabinet hartke figure4614 Instruments and Amps 4 9th April 2007 12:23 PM
Hitachi HA5500 help needed dejan Solid State 1 1st November 2004 12:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
