Instruments and Amps Everything that makes music, Especially including instrument amps.
BBE 1072cp 9627 IC
BBE 1072cp 9627 IC
Old 26th February 2020, 11:59 PM   #1
Scabab1359 is offline Scabab1359
Post BBE 1072cp 9627 IC
I am trying to repair an older model BBE sonic maximiser and I need a BBE1072cp 9627 integrated circuit. It is a 24 pin IC. 12 pins on each side. All I can find is a 1071cp 18 pin IC. HELp!!??!
File Type: jpg 633C8BC0-0CD4-4600-B874-BBCD87ED16FF.jpg (97.4 KB, 31 views)
Old 29th February 2020, 11:56 PM   #2
sgrossklass is offline sgrossklass  Germany
If you search for Exar XR-1072, you will at least turn up a datasheet for this one. Some help for troubleshooting if nothing else.
I did find at least one seller for the surface-mount (SOIC) version XR1072CD. How trustworthy I don't know, but I imagine you could bend the legs into enough of a DIP-like shape for it to work. Even if they're knockoffs, a lot of the internal circuitry is documented in the datasheet and a bit of educated guesswork and experience in analog chip design may well be sufficient to come up with a decent clone.
Old 1st March 2020, 12:23 AM   #3
Thank you. If all else fails I will get the surface mount ones and reverse engineer the board and build a new one.... might actually be a better idea then my original... so thanks a lot bud!!
BBE 1072cp 9627 ICHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
