Instruments and Amps Everything that makes music, Especially including instrument amps.
100 ohms Hum Balance pot
Old 8th February 2020, 12:06 PM   #1
Carlosraj is offline Carlosraj  United Kingdom
Default 100 ohms Hum Balance pot
Hi
I did a modification of this pot for a Fender Twin because the pot was damaged. I connected two 50ohms 1/2W resistors to each side of the filament terminals to ground. It worked OK for a while without any hum but then the 2 resistors burnt out. Do I need to put in higher power rated resistors or can I do away with this 100ohm pot, if the amplifier doesn't hum.
Old 8th February 2020, 11:58 PM   #2
Enzo is offline Enzo  United States
Um, you cannot have both resistors AND the hum pot at the same time.
We generally use 100 ohm resistors rather than 50 ohms. But the point is that there is not usually any ground current. Your pot or the two resistors are in series across the 6v. SO whatever current that draws. A pair of 100 ohm dissipates about 2/10 of a watt. If you use a 100 ohm pot - same as two 50 ohm resistors, then it dissipates 4/10 of a watt.
Old 9th February 2020, 04:10 AM   #3
PRR is offline PRR  United States
PRR's Avatar
How?? I assume this is a common 6.3VAC heater circuit. Then each resistor gets 3.15V. 3.15V in 50 Ohms is indeed 0.2 Watts, and a 1/2W should last "forever".
Something else is wrong. One possible is a heater shorted to other tube electrode.
You "can" have both pot and fix resistors. It's pointless and wasteful, but it won't burn.
100 ohms Hum Balance potHide this!Advertise here!
Mixing 2 parallel 8 ohms woofers with single 8 ohms tweeter SpartanX58 Multi-Way 4 11th November 2016 01:40 AM
8 Ohm 2X12 Guitar Speaker cabinet - 2X4 Ohms in series or 2X16 Ohms in parallel? KP11520 Instruments and Amps 38 17th September 2013 12:00 AM
8 ohms woofer plus 4 ohms tweeter? stf92 Multi-Way 9 27th August 2011 08:07 AM
15 ohms (12 on ohmmeter) with 24 ohms resistor in parallel to bring to 8 ohms McIntosh Man Multi-Way 29 11th June 2010 06:36 PM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 04:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
