Instruments and Amps Everything that makes music, Especially including instrument amps.
Digital potentiometer for volume control
Digital potentiometer for volume control Please consider donating to help us continue to serve you.
Old 12th November 2019, 09:23 AM   #11
sarathssca is offline sarathssca  India
we may look at the DS1882 digital potentiometer (doesn't have any opamps inside, just a analog signal potentiometer which is controlled digitally via i2c). it needs to be connected to a very high input impedance stage (may be a buffer - discreet/opamp). and also takes care of zero crossing issue and also needs dual supply upto +/-7v.
Old 12th November 2019, 09:47 AM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Tengil View Post
This one does look promising. However, there is a delay up to 16 ms before switching volume to eliminate the noise. .
This is only in the absence of a zero crossing. With normal signal, zero crossings happen all the time and switching is near-delay-less. Only when there is no zero crossing the device waits 16ms and then switches anyway. So it is more a safeguard to allow switching in the absence of signal than a normal operation. And if it switches in the absence of signal there is no noise anyway.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit
Old 12th November 2019, 10:30 AM   #13
adrianbaugh is offline adrianbaugh  United Kingdom
With zero crossing enabled the DS1882 allows itself a 50ms window to change resistance, which would not meet the OP's requirement.
Gyraf G9 || Tubelab SSE || Fostex FE126En in hybrid back loaded horn / bass reflex enclosure || Digital source (Volumio / RPi2 / Pi2Design 502DAC-Pro / Balanced Output board) || Stereo Modulus-86 based power amp
Old 12th November 2019, 11:55 AM   #14
jan.didden's Avatar
This is only in the absence of a zero crossing. With normal signal, zero crossings happen all the time and switching is near-delay-less. Only when there is no zero crossing the device waits 50ms and then switches anyway. So it is more a safeguard to allow switching in the absence of signal than a normal operation. And if it switches in the absence of signal there is no noise anyway.
Jan
Digital potentiometer for volume controlHide this!Advertise here!
Digital potentiometer as volume control Bricolo Solid State 39 6th March 2019 02:16 AM
Potentiometer as a volume control RRSS Construction Tips 10 31st March 2012 02:16 AM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 11:46 AM
Volume Control Potentiometer Recommendation? TheLaw117 Parts 3 18th September 2010 11:01 PM
Volume Control (potentiometer) SergeDufour Parts 1 6th December 2006 10:56 PM
Copyright ©1999-2019 diyAudio
