Instruments and Amps Everything that makes music, Especially including instrument amps.
Oscillation in effect loop
Oscillation in effect loop Please consider donating to help us continue to serve you.
Old 7th November 2019, 05:09 PM   #21
razorrick1293 is offline razorrick1293  United Kingdom
Ok, any pointers on good layout/wiring?
Old 7th November 2019, 10:55 PM   #22
Gnobuddy is online now Gnobuddy  Canada
Good layout is too big a topic to cover easily, and it's a bit of a "soft" skill, half art, half science. But here's a little write-up to get you started: How to Layout and Build a Guitar Amplifier Chassis - GuitarKitBuilder
That write-up is very incomplete - it only really talks about physical placement of the main components. It doesn't address wiring at all, and the wiring layout can make or break the build.
I'll see if I can find a good wiring layout write-up somewhere (there must be some!), but in the meantime, some general guidelines off the top of my head:
1) Keep wires as short as possible, within reason (i.e. don't fight to shave a millimetre off the length, but shave off an inch whenever you can.)
2) Don't run signal wires side-by-side and close together.
3) When possible, cross signal wires at right angles or nearly so.
4) Keep wires carrying low-level signals far away from wires carrying large signal voltages.
5) Keep output wires as far from input wires as possible - at every gain stage, as well as over the entire amplifier.
6) Route wires flat against the grounded metal chassis when possible; this reduces hum and noise pickup.
7) Use shielded cable (coaxial cable) for sensitive wiring carrying small signal voltages.
8) Distance is your friend in many cases - space wires further apart, keep outputs well separated from inputs, position gain stages a few inches apart. (Yes, this appears to contradict item #1, and you have to figure out a reasonable compromise.)
9) Grounding within the amp is critical. This is a whole topic by itself; the chapter on grounding schemes in Merlin Blencowe's Tube Preamp book is well worth reading.
-Gnobuddy
Old 12th November 2019, 03:12 AM   #23
thoglette is offline thoglette  Australia
thoglette's Avatar
The best advice I ever heard (I think first phrased this way by Lynn Olson) was
"think in loops"
Current flows in loops; voltage adds up to zero around loops and magnetic coupling happens in loops. A twisted pair is an anti-loop.
Capacitive coupling does take a little more visualisation but it's still in a loop. Shielding trys to block or cut loops. Static is probably the odd man out here but that's usually only a problem during construction
Oscillation in effect loopHide this!Advertise here!
How to add effect loop or line in to Fender solid state amp (Fender switcher) jjrt2 Instruments and Amps 2 10th November 2017 05:16 AM
Vds oscillation ml342001 Power Supplies 10 7th September 2007 09:02 AM
oscillation?? wintermute Solid State 8 13th July 2005 01:45 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 07:46 PM
Linx power amp Ground loop? Oscillation? I'm a bit lost :-( steve_v Solid State 43 17th February 2005 10:27 PM
Copyright ©1999-2019 diyAudio
