Instruments and Amps Everything that makes music, Especially including instrument amps.
Power Amplifier [150Euros]
Old 26th August 2019, 03:57 AM   #11
PRR is offline PRR  United States
PRR's Avatar
The value of the fundamental of a square wave is not 1.0 but 1.27. That does not cover the discrepancy, but reminds up that wave-smacking is not a simple thing.
Old 26th August 2019, 04:16 AM   #12
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by PRR View Post
And that link contains the sentence "A pure square wave with infinite harmonics has THDF of 48.3%,[1][13][14]..."
The first of those references is available online, and proved to be readable, at least initially; I was able to follow the calculation of THD for a square wave, and it is {square root of ( ((pi^2)/8) - 1 )}, which works out to 48.3%.
So you are correct, and my estimate is badly wrong.
I think I found the mistake I was making: I calculated THD for a square wave and sine wave of the same peak value, visualizing an amp gradually driven from clean into clipping.
But if you take the Fourier series of a square wave, the amplitude of the fundamental is not the same as the amplitude of the square wave...it's bigger! (And so, THD is lower.)
This leads to something I didn't expect at all: if you feed an amplifier a sinewave, and gradually turn up the amplitude till clipping starts, and then push it further into clipping, the amplitude of that fundamental-frequency sinewave continues to increase!
-Gnobuddy
Old 26th August 2019, 04:17 AM   #13
You posted that while I was composing my last post...I think we both found the error I was making at about the same time.
-Gnobuddy
Old 26th August 2019, 04:04 PM   #14
PRR's Avatar
Originally Posted by Gnobuddy View Post
And that link contains the sentence "... THDF of 48.3%..."
I didn't *read* my own citation! Thanks for spotting that.
Intuitively: if you tune your ear to just the 1kHz, and crank past clipping, the 1kHz *does* increase. Yes, that's not normal hearing: the harmonics cloud perception, and we are used to just hearing "louder" without reference to the fundamental. I would not trust my ears either way (blind or knowing). Band-filter meter would tell; so could a tuned pipe (snip of garden-hose) on an SPL meter.
me> reminds up that wave-smacking
Sorry, "...reminds us that wave-smacking..."
Old 17th September 2019, 09:29 PM   #15
forart.eu is offline forart.eu  Italy
Originally Posted by Entas View Post
Hello,
Checking some Power Amps, the one that I like the t.amp E-400 Thomann Lithuania. Can I find better one than this? Is this thing actually have 190Wrms @ 4ohm?
What about Behringher A800 (2 x 400W @ 4ohms) which is a fanless Class-D reference studio amplifier available between 170-180 ?
Power Amplifier [150Euros]Hide this!Advertise here!
Amplifier kit HOOD JLH 1969 Class A Power amp kit 2 channel amplifier 10W+10W hifisuran Solid State 2 21st July 2019 06:57 AM
Snail Power CA18 Professional Power Amplifier,Blown Fuse & Power Transistors shorted Peter Qiu Solid State 1 10th December 2016 12:01 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2019 diyAudio
