Instruments and Amps Everything that makes music, Especially including instrument amps.
The one valve guitar amp is dead, so ....
Old 10th August 2019, 01:45 AM   #11
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by snaarman View Post
So there you go: The Toolbox Twin.
Very nice!
-Gnobuddy
Old 11th August 2019, 09:23 PM   #12
Thomasha is offline Thomasha
Nice looking little amplifier!
Is the cathode follower better than a normal gain stage? Is it in front of the tonestack?
Old 11th August 2019, 10:09 PM   #13
snaarman is offline snaarman  United Kingdom
snaarman's Avatar
The circuit is like this:
FET preamp with adjustable non linearity to give an overdrive sound. Then there is a medium impedance tone stack based on the fender black face. Then volume control and first triode direct coupled to the cathode follower. That then drives both pentodes in parallel.
I decided I could not use both triodes for cascaded gain because I would have stability problems, so I used one as a cathode follower instead. It isn't a great design and two ECL82 valves make for a hot amp, but it sounds quite good..
Pete
Old 12th August 2019, 08:20 AM   #14
snaarman's Avatar
And here's the schematic. I think the only change I would make now it to fit better speakers, perhaps something with higher efficiency..
Old 12th August 2019, 08:39 AM   #15
Thanks for the schematic! For some extra distortion the tonestack could probably be used after the cathode follower too. The fet would hit the first triode much harder.
I was thinking... with a 10k OT it should deliver roughly 3W, only a little lower than what you have now, and you would have another pentode to use elsewhere. I never tried to use the pentode of the ECL82 as a gain stage, but it could work. That would definetely produce enough gain for some extra distortion.
But I'm also tempted to use the cathode follower as a cathodyne and make it a PP output stage. Would give almost 10W. I think the Westminster did that with ECL86 tubes.
The box really looks nice, are those 8" speakers for guitar or are they also radio speakers?
Old 12th August 2019, 08:46 AM   #16
snaarman's Avatar
In the spirit of making the amp out of leftover parts, there's a speaker from a Fender 15w bass amp in there, and one from a Tanglewood acoustic amp :-)
The bass speaker sounds brighter, the acoustic speaker sounds less toppy. Weird. They are small magnet things so it could be much louder with a pair of Celestion 8-15s.
Having attempted the one valve amp and failed, I just used the leftovers to make this object.
My amp design of choice is ECC83 then a pair of EL90s in parallel, SE class A. That can give 4 to 5 watts, and I have built a couple of those. They sound great with the right speakers...
Old 12th August 2019, 03:04 PM   #17
johnsurnamerobinson is offline johnsurnamerobinson
I use epiphone valve junior for guitar totally retro 50s down to to the chicken head knobs.Looks great, Very well made! Five ear splitting watts from class A single ended EL84.Eminance speaker inside.cost 119
Made in CHINA !!!!
Old 12th August 2019, 03:13 PM   #18
Made in CHINA !!!!
Old 13th August 2019, 10:17 AM   #19
snaarman's Avatar
Novel idea. I was wondering why you don't usually see the tone stack after the driver triode.. and I guess that's because it puts the tone stack inside the negative feedback loop if there is one. And that is probably not a good idea from the point of phase and gain margins perhaps..
As to Epiphone amps: Yes, it was listening to their Chinese 5 watt amp that got me back in to amp design.
Instead I bought a second hand Fender Champ 600. It had so much hum I had to get in there and rework it straight away. Then I gave it a tone control and mild over drive.
And the rest is history, I now have four or five home designed valve amps under my belt and - alas - no sign of stopping
Pete
Old 13th August 2019, 07:42 PM   #20
snaarman's Avatar
Here's a sound cloud sample of this Toolbox Twin - recorded with a capacitor mic and using my Luthier modified 3 pickup Yamaha Telecaster..
Toolbox Twin Amp Demo by Pete Hanson | Free Listening on SoundCloud
The one valve guitar amp is dead, so ....Hide this!Advertise here!
70's valve guitar amp needs TLC ammers2 Instruments and Amps 44 4th February 2019 02:05 PM
Less than 1w practice guitar amp Tube Valve tehmessiah Instruments and Amps 11 20th December 2016 03:01 AM
Guitar Valve Amp Output Transfomers shunt94 Instruments and Amps 12 7th April 2011 09:45 PM
Laney guitar amp, pre amp is dead stevekendal Instruments and Amps 6 18th August 2010 07:29 PM
big valve traffo for guitar amp? Craig405 Instruments and Amps 15 9th October 2007 09:53 PM
Copyright ©1999-2019 diyAudio
