Instruments and Amps Everything that makes music, Especially including instrument amps.
Philicorda 22GM751 - Reverb Missing
Old 16th June 2019, 07:55 AM   #1
pelaurendeau is offline pelaurendeau
Default Philicorda 22GM751 - Reverb Missing
Hello everybody,
I just bought a Philicorda 22GM751. The guy who sold it to me, told me straight away than the reverb wasn't working, but everything else was ok. I didn't had time to open it when I was there and thought also than it could be just a bad component somewhere. But actually, the all spring tank is missing !
I had access to another (fully working) 22GM751 but there is nothing wrote on the tank (like Accutronics tanks).
So my question is, does anybody know the reference of the spring tank, or his impedance in/out, or more easily, what would be a good replacement tank ?
​​​​​​​Thanks !!
Old 16th June 2019, 08:28 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The tank is driven directly from the loudspeaker output on this model, through a matching transformer.
If you select a tank with a medium input impedance, say 800R, that should work fine.
Like this one; Reverb Tank Short 3 Spring Medium Decay 8EB2C1B Guitar Tube Amplifier 800 ohm | eBay
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th June 2019, 07:30 PM   #3
Mark Tillotson is offline Mark Tillotson
That sounded most odd, so I looked up http://modularstudio.nl/docs/PhilicordaGM751.pdf and its true - one speaker amp drives the tank, its output is routed to a different speaker + amp!
Old 18th June 2019, 07:10 AM   #4
Thanks for the answers !
What about the output impedance ? Does it matter ? I'm not really good with electronic, but if there is a simple way to find the impedance with a VOM on the spring tank of the other Philicorda, I could try !
Also what about the connectors Insulated or Grounded ?
From what I saw on the other Philicorda, it look like a Type 9 spring tank but I have no idea about the decay if it's medium or long, so a 9EB2C1B or 9EB3C1B tank ?
Old 18th June 2019, 07:42 AM   #5
Older machines used long delay tanks but it is only a matter of taste. Long delay tanks have longer springs.
Output impedance is of no consequence as there is plenty of gain on the pickup side.
The layout is as per the attached, for clarification.
Old 18th June 2019, 07:51 AM   #6
Bill Coltrane is offline Bill Coltrane  Netherlands
The ideal decay time depends on what you play.
Do you play long sustained chords, use a long delay.
Play stacato, short delay.
Spring reverbs are dirt cheap, diy a switch and you can use several spring reverbs.
Subjective measurements with the proper protocol is the only thing that matters.
Old 19th June 2019, 01:24 PM   #7
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
These reverberation tanks were proprietarily made by Philips for their Philicorda's. They can't be compared to any tank from Accutronics/Belton/Gibbs/Hammond, as they're longer than the short ones, but shorter than the long ones we all know. Maybe 8" to 10" long. And they're open frame, not in a closed can like the Accutronics.
Unfortunately my own Philicorda is stored away, and I don't have the time at the moment to go there, open it and shoot some pics or do measurements .
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 20th June 2019, 07:47 AM   #8
That's what I was afraid of .. The tank seemed a bit different to what I'm use to but I thought and hoped the way it's suspended was the only thing really different ..
Well I guess, either I find a dead Philicorda somewhere or I'll have to go for a not original tank and hope it's not to far from the original..
Philicorda 22GM751 - Reverb MissingHide this!Advertise here!
El-cheapo Reverb tank or Digital reverb? avtech23 Instruments and Amps 65 21st December 2018 05:37 PM
reverb for a 5F1 ampman33 Instruments and Amps 2 17th February 2017 01:54 PM
Reverb recovery stage with AC125 transistor in Philicorda GM751 organ - problems Princeton9206 Instruments and Amps 10 19th October 2015 11:51 AM
Missing reverb tank rogerbarry Instruments and Amps 4 1st March 2015 05:04 AM
Super Reverb AA270 reverb weak cancon Instruments and Amps 10 25th September 2014 11:16 PM
Copyright ©1999-2019 diyAudio
