Instruments and Amps Everything that makes music, Especially including instrument amps.
Zero experience! Wanting to learn with Sidechain EQ - reasonable?
Old 14th June 2019, 07:24 PM   #1
mzocoh is offline mzocoh
Default Zero experience! Wanting to learn with Sidechain EQ - reasonable?
Hello - this is my first post here. First off - I know next to nothing about audio electronics, DIY, mods or repairs but have wanted to for years so I joined here to see if I can get a start. I have loads of experience in audio processing but experience with processing & production does not equal knowledge of the electronics - in that regard I'm lucky if I can solder two wires together on the 1st try.
I'd like to design and build a relatively-easy something I'll actually use, not just a test project. At the moment I'm looking for a sidechain EQ for compression control. Without knowing the complexity of designing such a thing I've come up with this concept - it would cover almost any sidechaining need I may encounter:
HP 20-350, 18db/oct slope
Peak 20-20k / -12db/+12db / Variable Q (1.0-8.0)
Shelf 20-20k / Fixed Q 1.0 / -12db/+12db
1/4" In + Out (TS / TRS?) for interfacing with pro level gear / SC
(I assume this would be an active design to keep it simplest, but unsure.)
Now, I have no idea how complex this would be, especially with the crossover frequencies and the parametric band - from what I've found a HP is quite simple, but no idea about the complexities when it's integrated into such a design. Can anyone comment / point me to a place to start or fill in the blanks (and they're mostly blanks) about what this would involve?
Thanks!
Old 14th June 2019, 08:41 PM   #2
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
First question. Are you sure these slopes are what you want? If not and you have a linux laptop then give the calf studio tools a run as they allow you to test out the filters you want digitally and be sure you are choosing the right ones.
I would also pop over to Pro Audio Design Forum - Pro Audio Design Forum and have a look at some of the designs there. They are a friendly bunch and lots of schematics posted for exactly what you want to do.
Looking at your requirements a variable Q peaking filter that can do the entire audio band could get tricky as you are switching a lot of components. 3 Bands would make more sense here. But nothing impossible, although I would make it modular so you can add as required.
Old 14th June 2019, 09:00 PM   #3
00940 is offline 00940  Belgium
00940's Avatar
Two things I would do:
- get a copy of the small signals design book by D. Self.
- have a look at the forum groupdiy.
All that is excessive is insignificant. Talleyrand
Old 14th June 2019, 09:28 PM   #4
The applications for side-chaining in the way I'd be using it should be well covered by those filters. I didn't spend a ton of time coming up with them - 15 minutes with a digital parametric EQ and knowing the dozen or so ways I use sidechaining - of course if people are already building dedicated multi-band sidechain filters there certainly may be better, time-tested designs and I'd want to take a look at those to see if there's more sense in an existing design (and its filters) rather than reinventing, especially considering my newbie-ness!
I do have a linux VM available, but is there anything more calf studio would provide over using an EQ (Acon Digital's EQ) as I did? I had a look at all the slopes and interactions and they add up for my usage.
On the 20-20 variable - are you saying this would be better split into 3rds (of the total 10 octaves) and incorporating 2 additional pots (+ Q for each & gain for each)? - it's stuff like this (why the full range would be possibly problematic) where I don't know a thing, though I chose that thinking that the design would be much easier and liked the idea of only 3 pots for frequency selection..
Thanks for the input - I will check out any / all DIY pro-audio forums I can find - I'll pay a visit to the one you mentioned.
Old 17th June 2019, 07:48 PM   #5
Mark Tillotson is offline Mark Tillotson
One way to cover 1000:1 frequency ratio is to use 10:1 potentiometer range and 3 switched capacitances - one circuit, but switched. Very large ratios of resistance are a problem as large resistances introduce noise, and small resistances are hard to drive from the previous stage.
30:1 potiometer range and two switched capacitances is also feasible.
Old 18th June 2019, 05:19 AM   #6
Mark - so in that design, would the mid-range be switchable - 10x, 100x, 1000x? There are a lot of EQ designs with a switch for multiplier w. a common gain & Q control - as such?
Old 19th June 2019, 09:52 AM   #7
I am talking in general about variable frequency active filters of any kind - the large ratios are an issue. Surely mid-range has only a very small ratio of 500 to 3000Hz anyway?
Zero experience! Wanting to learn with Sidechain EQ - reasonable?Hide this!Advertise here!
Reasonable headphones for £30? scottjoplin Headphone Systems 32 24th December 2018 08:26 PM
does this little BVR look reasonable ? freddi Subwoofers 1 6th August 2016 03:28 AM
wanting to buy oldschoolamp Car Audio 0 1st August 2015 11:10 AM
Wanting to go OB again... chops Multi-Way 26 18th July 2012 03:58 PM
Just wanting to say thanks. Dawg Dayez Car Audio 2 6th April 2010 01:56 AM
Copyright ©1999-2019 diyAudio
