Instruments and Amps Everything that makes music, Especially including instrument amps.
Is it easy to transform a volume pedal into a USB MIDI controller?
Old 5th June 2019, 03:27 PM   #1
amundsen is offline amundsen
Question Is it easy to transform a volume pedal into a USB MIDI controller?
Hello,
I have a Roland passive volume pedal. I want to transform it into a MIDI USB foot controller. I plan to use a Teensy microcontroller as an analog to USB converter.
However I have a few questions about the analog part of the circuit:
1. Is it mandatory to send some signal to the pedalís input and take the pedalís output as information to be digitized or is there some way to avoid sending a signal to the input?
2. In case itís mandatory to send a signal to the pedalís input, would you rather recommend to use an AC or a DC signal?
Thank you.
Old 5th June 2019, 11:50 PM   #2
Mark Tillotson is offline Mark Tillotson
DC, it will just be a potentiometer. However it will likely be log-law, and you would be better with a linear-law pot for digitizing the wiper voltage - it may be possible to replace the potentiometer part of the pedal if it uses standard variety of pot (and not some special purpose one)
Old 6th June 2019, 09:57 AM   #3
Gerrit Boers is offline Gerrit Boers  Netherlands
The Using USB MIDI contains general information and at the bottom there's a link to a foot pedal controller that might be just what you're looking for: Footsy - Teensy 2 based MIDI foot pedal controller
Old 7th June 2019, 06:44 AM   #4
I have found this article using a simple split-cable but I have to check whether my pedal has a linear or a logaritmic resisance if I want to use it with a linear ADC.
This one explains how to hack the pedal itself.
Thank you everyone!
Is it easy to transform a volume pedal into a USB MIDI controller?Hide this!Advertise here!
Diy midi controller Aidan91 Instruments and Amps 1 27th February 2019 07:41 AM
Trying to build myself a midi controller. arnob Instruments and Amps 1 18th February 2019 02:18 PM
Adding volume pedal to umx61 midi keyboard bumblebee001 Instruments and Amps 27 24th January 2009 11:21 PM
need help with MIDI controller mod jimminy Instruments and Amps 7 26th January 2007 06:36 PM
need help with mod for MIDI controller jimminy Digital Source 0 2nd December 2003 06:13 AM
Copyright ©1999-2019 diyAudio
