Instruments and Amps Everything that makes music, Especially including instrument amps.
How to measure the output impedance of a valve preamp?
Old 20th May 2019, 10:10 PM   #11
i3alan is offline i3alan  Canada
This a guitar preamp pedal. It will be used in line with the other guitar effects, plugged to the front end or to the power amp directly. Yes, the low pass filter is intended.
Old 20th May 2019, 10:20 PM   #12
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
moved to instruments and amps
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 20th May 2019, 11:44 PM   #13
rayma is online now rayma  United States
Originally Posted by i3alan View Post
my Z out is getting as low as 3k3 and the output signal is meeting a very low resistance. While the logic says it is actually the opposite.
The circuit's output impedance is 40k, and you are loading that with 3k to ground. The voltage divider formed by these two resistances reduces the output level a lot, more than a factor of ten.
However, the output impedance of the circuit with the 3k in place is changed from 40k to 3k. You would have to study Thevenin's theorem to have an intuitive understanding of it. Failing this, just accept that the output impedance of the circuit with the 3k load is the 40k in parallel with the 3k.
The Thevenin Theorem - A Simple Explanation - Build Electronic Circuits
Old 21st May 2019, 03:18 AM   #14
PRR is offline PRR  United States
PRR's Avatar
If you truly need 3K on the output to get your signal level, then of course Zout will be <3K.
With your backward-connected Master Volume pot in the latest plan, final Zout will vary from 250k to <3K. To my mind, _I_ would think to look at a normal-connection 5K pot (possibly with 10K across to make your 3K) which would give <5K at all settings and be much less susceptible to various loadings.
Old 21st May 2019, 03:43 AM   #15
Thank you, PRR.
So, I got the concept of the output impedance all the way wrong.
Could you tell, on the most basic level, the definition of the output impedance in such circuits and how it will interact with the different loads?
I am just trying to get the basic simplified idea of it.
Old 21st May 2019, 10:02 AM   #16
DF96 is offline DF96  England
You can model the output of almost any circuit as a voltage source with a resistor in series with it. The voltage source will give whatever voltage it gives, however much you load it. The series resistor will drop some voltage if you take some output current. You can use Ohm's Law to calculate how much voltage drop. The series resistor in this model is the output impedance.
Old 22nd May 2019, 01:35 AM   #17
djgibson51 is offline djgibson51  New Zealand
Side issue: Adding a tone stack of your choice prior to the volume pot will drop output level. Tone controls after distortion are good for guitar preamps.
Old 22nd May 2019, 01:49 AM   #18
See post #6.
Old 22nd May 2019, 04:14 AM   #19
PRR's Avatar
> output impedance
Why do you even care??
If you do, I suggest you study Voltage Dividers. EVERYTHING can be analyzed as a voltage divider. It is a powerful concept.
Old 22nd May 2019, 01:23 PM   #20
The post #6 shows one of the ways to calculate the output Z. Which I can totally understand. I care about the output impedance topic just because I would like to understand the concept of the correct signal matching. To my understanding the lower the output impedance is - the better. The ideal z out is 0. But I am confused by the fact that in real circuit Zout is going down when the output signal is pulled to ground. Which is not a good thing for a signal, right? I guess I am missing something between the lines.
How to measure the output impedance of a valve preamp?Hide this!Advertise here!
Please help how to measure/guage output of guitar preamp garybdmd Instruments and Amps 21 25th October 2016 01:51 AM
12AU7 Valve output impedance. nigelwright7557 Tubes / Valves 18 7th August 2016 10:50 PM
How to measure amplifier`s output impedance wrt Frequency? rhythmsandy Solid State 10 10th September 2014 07:06 PM
How to measure the output impedance of the DAC chip ergo Solid State 2 9th June 2004 07:07 AM
How do I calculate (or measure) my amp's output impedance? Saurav Tubes / Valves 22 27th September 2003 03:55 AM
Copyright ©1999-2019 diyAudio
