On my 50W Marshall clone amp, the normal channel is perfectly silent (no hum, no noise) the other channel, bright channel, does introduce a lot of sssssshhhhhhhhhh noise even without anything plugged into it. The normal channel is I believe with 820ohm cathode resistor and 330uF cap. The bright one is with 2k7 cathode resistor and 680nF cap.
What the heck is going on? Where is the noise coming from? Is it the 500pF cap across the volume pot after the first 12AX7 that makes that noise?
