Instruments and Amps Everything that makes music, Especially including instrument amps.
JRC 4558D - Guitar preamp
Old 15th April 2019, 10:12 AM   #21
Ben Martin is offline Ben Martin  Portugal
Originally Posted by JMFahey View Post
MJF solved and drew it for you ...
Whoa... I didn't realize that...
MJF, so sorry for that and many thanks for taking the time to simulate this!
I thought the schematic was some example you took from the web. Silly me.
I noticed that you used the RC 488D as reference.
I'm using the JRC NJM4558D.
I guess your test schematic applies all the same (the resistor and capacitor values) since both op amps are practically clones?
Much appreciated.
JMFahey, many thanks for pointing out this for me.
I was completely out of focus about MJF post.
Old 15th April 2019, 11:00 AM   #22
mjf is offline mjf  Austria
[QUOTE=Ben Martin;5761176]
hello,
...........i used a RC4558D in the schematic.......
Old 15th April 2019, 02:00 PM   #23
craigtone is offline craigtone  United States
craigtone's Avatar
I'd probably also add a bulk 100uF/220uF electrolytic per rail where the power enters the PCB.
Craigtone Audio
Soundsmith Boheme, WT Classic, Pearl 2, Apollo-R, Burson Swing, Hafler 915, TSE 45, ALK Klipschorns
Old 15th April 2019, 07:07 PM   #24
Hi all,
I reached the final design for this project.
I leave it here for anyone that may wish to do this guitar preamp BOX (for 4 guitars).
The main idea of this project was to raise the guitar signal from "Instrument level" to "Line level".
Many thanks to all of you that commented and suggested on how to change this project for better.
My special thanks and gratitude to MJF and JMFahey.
I decided to replace all POTs with fixed values resistors (R3, R4, R15 and R16) like suggested by MFJ and JMFahey, yet, if someone would prefer to use "volume" pots, then replace these resistors by POTs.
NOTE: I decided to go for a dual layer PCB.
In the front side of the PCB I decided to put only the +12v; -12V; tracks (in red).
The rest of the circuit will be printed in the PCB back side (in green).
@craigtone
I understand your worries, yet the Power Supply Regulator Circuit is already well filtered, (see the PWSR schematic), unless you see any other reason to use those capacitors, that I'm missing.
If anyone else notices any problem or issues with this circuit, please mind to comment on it.
Many thanks.
JRC 4558D - Guitar preampHide this!Advertise here!
preamp regulated or unregulated 4558d rahulrahullll Analog Line Level 4 3rd January 2018 06:55 PM
Guitar preamp argonrepublic Instruments and Amps 2 30th January 2017 04:29 AM
4558d auto pilot Analog Line Level 4 7th January 2013 07:42 PM
guitar preamp star882 Instruments and Amps 5 1st May 2007 02:37 AM
low THD guitar preamp Antonix Instruments and Amps 4 29th June 2006 04:49 PM
Copyright ©1999-2019 diyAudio
