Instruments and Amps Everything that makes music, Especially including instrument amps.
First amp build: low output and gated sound
Old 21st March 2019, 03:59 PM   #1
Max999 is offline Max999
Default First amp build: low output and gated sound
I tried my first amp build, a Marshall 2203, and it has very low output and a gated fuzz sound.
The tubes are replaced and should work. The output tubes feel hot to me, and before there is silence, the amp screaches softly. I suspect oscillation.
Or I forgot some connections offcourse.
Does anybody has an idea where to start checking with these symptoms?
Old 21st March 2019, 05:39 PM   #2
knockbill is offline knockbill  United States
knockbill's Avatar
Can you post a schematic...
John
Old 21st March 2019, 05:48 PM   #3
Sorry, schematic is attached now.
I have full output and lost the gated sound now: bad ground in the p.i.
Now the amp sounds good but hums even with a grounded input.
Hum is most likely a bad grounding scheme? What could be other causes?
Old 21st March 2019, 06:02 PM   #4
knockbill's Avatar
The grounding layout may contribute,,, AC heater leads near signal wires,,, loose connections... Its hard to say without seeing the chassis...
John
Old 22nd March 2019, 12:03 AM   #5
Printer2 is offline Printer2  Canada
Pull the input tube, turn it on how is the hum. If still there turn off and pull the second tube, turn on and check, if still there repeat with PI tube and turn on.
Old 22nd March 2019, 12:34 AM   #6
rayma is offline rayma  United States
There are pots after the first stage, and also after the tone.
Does the hum reduce when either or both pots are turned to minimum?
Old 22nd March 2019, 01:58 PM   #7
indianajo is offline indianajo  United States
indianajo's Avatar
Perhaps the power transformer is too close to the gain stages. Does it have a ferrous wrapper? If not you you may have to build a steel wall around it.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 22nd March 2019, 02:38 PM   #8
Moving the input wire of V1 away from the heater wire helped a ton but there is still hum Knockbill.
Printer2, pulling V1 kills most of the hum.
Rayma, turning the preamp pot down solves most of the hum.
Indianajo the PT is on the other side of the chassis.
Hmm this sounds like V1A is the culprit, but what to do with it... Time to elevate the heaters?
Old 22nd March 2019, 02:57 PM   #9
hex69 is offline hex69  Canada
hex69's Avatar
I experienced something similar once, maybe it could help.. was playing with my hand between the output transformer and V1 then I noticed some variations in the hum, so I think it would be a good idea to shield the preamp tubes using those aluminium spring loaded cap.. hum goes away.
Old 22nd March 2019, 05:50 PM   #10
Thnx Hex, but I am already using the preamp shields.
First amp build: low output and gated soundHide this!Advertise here!
What is bottom-gated dual back load horn baski Full Range 1 7th October 2016 03:39 PM
Theoretical problem with gated impulse response Chaotikmind Software Tools 11 18th July 2016 11:13 PM
Gated frequency measurment lup31337 Software Tools 1 11th April 2016 03:10 AM
Noise Reduction DIY >not gated< DIY? orson198305 Instruments and Amps 3 25th June 2006 06:24 AM
Copyright ©1999-2019 diyAudio
