If you wire it correctly, before the rectifier, centre tap of transformer to ground through switch or if a single winding, in series with one of the AC feeds to the bridge, that will avoid the need for a DC type switch. A standard 250v AC switch will then be fine.
Some Marshall amps are wired BEFORE the main smoothing capacitor, that reduces the DC across the contacts.
- Live Sound
- Instruments and Amps
- marshall 18 watt tremolo psu question
