Instruments and Amps Everything that makes music, Especially including instrument amps.
marshall 18 watt tremolo psu question
Old 14th February 2019, 02:24 AM   #31
PRR is offline PRR  United States
PRR's Avatar
Then it is likely a 6k6 primary and two secondaries you can connect for either 4 or 16 Ohms.
Old 17th February 2019, 04:24 PM   #32
intensate is offline intensate  United Kingdom
intensate's Avatar
It would seem like I have 2 4onm taps?
And el84 need an 8k transformer so I may need to get one?
Old 17th February 2019, 04:36 PM   #33
OrbitalLex is offline OrbitalLex  United States
6.6k is fine for el84's. I doubt you have 2 four ohm taps. Is there a code stamped into the bell of the transformer? That may help determine the make and color code.
Old 17th February 2019, 05:03 PM   #34
intensate's Avatar
just had a loo inside the bells ,nothing written
only markings are 1100 on top
pink and yellow are one winding,blue and oronge other set
Old 17th February 2019, 05:06 PM   #35
Is there anything stamped on the outside?
Old 17th February 2019, 05:10 PM   #36
intensate's Avatar
nothing on outside apart from 1100 printed on it
thanks
Old 17th February 2019, 05:14 PM   #37
intensate's Avatar
only thought I had was to feed a 1khz 500mv p p signal from my scope into its sec and measure volt at pri? to see if I get different readings
Old 17th February 2019, 05:18 PM   #38
That redish pink lead is likely your b+
Blue and yellow leads are likely plates
Old 17th February 2019, 05:30 PM   #39
intensate's Avatar
the pri winding are brown, black ct and red that exit otherside
Old 17th February 2019, 08:02 PM   #40
PRR's Avatar
Put the two secondaries parallel for 4 ohm, series for 16 Ohms.
It might help to describe this "donor".
marshall 18 watt tremolo psu questionHide this!Advertise here!
Custom Marshall 18 Watt - TMB blackwhaleamp Instruments and Amps 5 12th January 2018 07:12 PM
18 watt Marshall diy reallyjake Swap Meet 0 6th December 2016 04:09 PM
18 watt tremolo vvr bagudan Tubes / Valves 0 17th May 2012 09:43 AM
Marshall 18 watt famousmockingbird Instruments and Amps 4 21st April 2012 06:21 PM
Marshall 1959 (Super Tremolo) repair help morta Instruments and Amps 11 26th September 2010 09:01 PM
Copyright ©1999-2019 diyAudio
