Instruments and Amps Everything that makes music, Especially including instrument amps.
Marshall Code 25 - FX Loop
Old 24th January 2019, 10:10 AM   #1
Pontiac51 is offline Pontiac51  Austria
Pontiac51's Avatar
Default Marshall Code 25 - FX Loop
Dear DIY Audio Gods! Sorry to say that, but I am still thrilled how you all brought me forward on my last project. Cannot say it often enough, you guys rock!
My newest project is to relocate a Marshall Code 25 from the combo to a head housing (again). If you are interessted, read the full story here:
DIY Code 25 Rebuild
Now, a fellow reader (thx to dpaterson) has pointed out that the Code 25 misses an FX loop in contrast to its bigger brother, the Code 100. He has found the right points on the PCB by trial and error (and without exploding something) and I want to build on that.
So I have scratched up the simplest wiring diagramm I could think of and would like to request you to have a look at it. I am trying to stay as minimalstic as possible (as you have teached me) and then enhance further once basic functionality is confirmed.
Please do not hesitate to point out weaknesses or errors in the wiring.
Pin1 is ground, pin3 is signal. Pin2 and 4 are NC.
File Type: png Schematic_Code-25-FX-Loop_Sheet-1_20190124110730.png (26.5 KB, 61 views)
Old 24th January 2019, 06:46 PM   #2
PRR is online now PRR  United States
PRR's Avatar
The switching should be on the Return, see snip stolen from
Bass Guitar Amp 2
Your level control as-shown will be troubled. Full down it shorts-out whatever is trying to drive it. If you use it to drive the power stage while ignoring the preamp (aside from using a different preamp, VERY valuable for trouble-shooting), half-up the 500k half-pot will make hardly any difference to the presumably low-Z signal from Send. Full up Return and Send fight each other unless you brought a dummy plug/cord for the Send jack.
This is not a new invention. Plagiarize.
Old 25th January 2019, 06:55 AM   #3
Pontiac51's Avatar
I see. Thank you for pointing this out.
How would you realize a level control, if at all possible? And how to size it properly?
I have changed my first design accordingly and did another which should be a classic too. But again, how to dimension the pot? I found values ranging from 22k to 1M. Does it matter?
File Type: png Schematic_Code-25-FX-Loop_Sheet-1_20190125075146.png (25.6 KB, 39 views)
Old 26th January 2019, 08:37 AM   #4
Pontiac51's Avatar
I combined the circuits with a switch. Is this still correct? Any input on the pot I should use?
File Type: png Schematic_Code-25-FX-Loop_Sheet-1_20190125215830.png (14.4 KB, 25 views)
Old 27th January 2019, 05:13 AM   #5
PRR's Avatar
The pot depends on SO many factors I can't guess from here.
100K seems a likely value.
Old 27th January 2019, 04:29 PM   #6
Pontiac51's Avatar
Thank you. I will start from there.
Marshall Code 25 - FX LoopHide this!Advertise here!
how to add LTspice code supernut Software Tools 2 28th February 2017 05:15 AM
Problem witht [code]blah[/code] ? elseif Forum Problems 1 17th August 2008 01:30 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 07:46 PM
Anyone know the date code on these? K-amps Solid State 8 23rd February 2005 09:20 PM
Copyright ©1999-2019 diyAudio
