Instruments and Amps Everything that makes music, Especially including instrument amps.
How to use 20K pots for hi-Z guitar pickup?
Old 24th January 2019, 02:18 AM   #11
dotneck335 is online now dotneck335  United States
Originally Posted by JohnDH View Post
One jfet transistor makes a very good buffer, with low current draw. I have a few of these in guitars and stomp-boxes. I think the values here will drive a 20k load ok, with moderate input.
I think this circuit still leaves you with >20KΩ of source impedance, which really isn't much of an improvement. Use the OPA145 in a single-supply source-follower arrangement and it will have close to zero source impedance.
Old 24th January 2019, 03:32 AM   #12
JohnDH is offline JohnDH  Australia
Actually its effectively much less, controlled by the resistance between drain and source. It works out around 2k. If the load tries to drag the output down, the gate to source voltage reduces and the jfet switches on more to compensate.
Old 24th January 2019, 04:51 AM   #13
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
That FET buffer will work very well, and will properly drive a 20k pot.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 24th January 2019, 06:30 AM   #14
voltwide is offline voltwide  Ireland
agreed. I Use this circuit for decades inside my axe.
tuby or not tuby, that is here the question!
Old 24th January 2019, 09:34 AM   #15
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by voltwide View Post
Yes, a buffer is the way to go. With the buffer installed you can parallel some resistor to your pickup-coil to dampen hi-frequency resonant peak.
Well, this peak is no bug at all, it's a feature that significantly forms the guitar's sound! So, if any active electronics is put between the PU and the guitar cable, the missing cable capacitance should be substituted by a discrete capacitor. Otherwise the axe will sound flat and boring.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 24th January 2019, 06:21 PM   #16
The peaking is a matter of taste, too much of it gives you sound like a wah-wah. Parallel-caps are the same - I suggest more capacity (around 1~2nF) when playing heavy distorted and less (220p~470pF) for the cleans sound with a strat. Values for the bass might differ.
Old 24th January 2019, 09:24 PM   #17
Isn't that what a tone control does?
Old 24th January 2019, 09:49 PM   #18
I do not think that the traditional tone stack can afford this. A parametric equalizer could do the trick - but this is way to complicated for the average joe. And besides it makes a great difference inserting the tone control before or after the overdrive stage.
Old 25th January 2019, 04:14 AM   #19
PRR is offline PRR  United States
PRR's Avatar
I do not think that the traditional tone stack can afford this...
I think Dotneck meant the knob on the guitar. A variable resistor and a modestly large cap. Zero-R it puts a big whack on the treble much as I understood you to be suggesting.
Old 25th January 2019, 09:05 AM   #20
That's right, and just to add to tbat:
A normal guitar is significantly affected by the capacitance of the cord, which interacts with the pickup to make a treble peak at say 3-4khz, with a fall above that. A buffer stops that interaction, giving a flatter, more hi-fi extended treble response. It can sound great, but it may sound different. So to reproduce it with a buffer, a very small cap can be added across the buffer input, to ground. Its worth trying, but it may be preferred without. The change is not the same as a standard tone control, so it can't be recreated that way.
How to use 20K pots for hi-Z guitar pickup?Hide this!Advertise here!
Guitar Pickup Wiring razorrick1293 Instruments and Amps 9 11th September 2015 10:32 PM
guitar pickup pre / phase flipper dataplex Chip Amps 57 13th April 2014 10:57 PM
Sustainer guitar pickup cartem Instruments and Amps 1 2nd July 2009 10:53 AM
guitar pickup fading ThSpeakerDude88 Instruments and Amps 4 31st January 2006 06:15 PM
pickup buliding for toy guitar? voteforgoat Instruments and Amps 3 14th April 2005 08:26 AM
Copyright ©1999-2019 diyAudio
