Instruments and Amps Everything that makes music, Especially including instrument amps.
Heater voltage too low
Old 16th January 2019, 06:06 AM   #21
aut0m4tic is offline aut0m4tic  United States
I'm with Nigel
I made up a 3 gang electrical box with a 12.6v ct transformer wired as an auto transformer. I used one side to install a light switch, and the other to install an outlet.
There is a tab between the set screws that you can cut to separate the top and bottom plugs from each other. That way I have one socket that is 6.3v lower than my line voltage, and the other plug is 12.6v lower.
I could have just as easily used it to raise the voltages by the same amount, just by swapping the secondary leads around.(google transformer polarity test, and you will get info on exactly what's going on)
This way, you never have to modify an amp to run a vintage transformer on today's higher voltages
In the photo, the top socket is line voltage minus 6.3, and the bottom socket is line voltage minus 12.6v.
The secret is to understand that a transformer doesn't care which side you feed it from. You have to be very careful not to put 240 onto the 12v, or secondary side, because you'll get 4500+v on the primary side, and more than likely smoke, flames and a tripped breaker.1547618149376.jpeg
Heater voltage too lowHide this!Advertise here!
DC voltage leaking into AC voltage heater rail jimmy74 Tubes / Valves 20 1st July 2018 02:30 PM
Elevating Heater Voltage with multiple Transformer Heater Secondaries mbeards Tubes / Valves 5 26th June 2013 05:32 PM
heater voltage Jaap Tubes / Valves 3 19th November 2008 12:39 AM
Too low heater voltage? jkeny Tubes / Valves 6 26th August 2008 01:08 AM
heater voltage: why ac, and not dc? alex278 Tubes / Valves 18 7th October 2005 01:21 PM
Copyright ©1999-2019 diyAudio
