Instruments and Amps Everything that makes music, Especially including instrument amps.
Instrument single input channel selector pedal switch
Old 5th January 2019, 01:15 AM   #11
PRR is offline PRR  United States
PRR's Avatar
> If you've half a brain you'll be able to do this with a handful of relays.
Is that a dig?
My half-brain leads to 5 relays, 4 large e-caps, and tangled wiring.
Search "Ladder Logic" today and you mostly get software emulations of true relay logic.
Old 5th January 2019, 01:22 AM   #12
mandu is offline mandu  Singapore
You can use four of MAX16054 switching IC to do this function. Use 4 momentary push buttons for each of the ICs input. Wire 3 diodes from each switch output to 'clear' of other three ICs.
Switch bounce is taken care of the IC.
Each IC has high and low outputs at 5 volts logic level which you can use to drive a FET switch or relay as necessary
mandu
Old 6th January 2019, 11:45 AM   #13
thoglette is offline thoglette  Australia
thoglette's Avatar
Is that a dig?
No, not at all.
That's just me being too lazy to work it out; capture the results and post them here
Probably about right; depending on which relays you have handy (we used to have ones with lots of poles for AND and OR). You can cheat with a handful of diodes.
Just as lazy today
Yup, but the ideas are the same. Ish.
Old 6th January 2019, 01:08 PM   #14
if you go with relay, you will need 4 relays + 4 FET or 8 relays.
See sketch attached.
regards,
Mandu
Old 7th January 2019, 02:24 AM   #15
PRR's Avatar
> you will need 4 relays +......
Thank you!
Indeed elegant as ladder-logic drawing.
Requires (practically) 4PDT relays, and a LOT of contact busing.
On the audio side, I would use a different form of switch (shunt loads the sum point; series would not) but that is a minor detail.
If a 5PDT relay were commonly sold, seems the audio end would be done. And of course a xP2T relay can be paralleled-up from 2P2T forms (parallel the coils and the contacts follow).
LED indicator (a must in the distraction of performance) is trivial.
I'm not sure anyone unfamiliar with relay logic forms and conventions will quickly grok that wiring.
Instrument single input channel selector pedal switchHide this!Advertise here!
input selector switch replacement help 1108 Tubes / Valves 8 8th April 2013 09:11 PM
Input Selector Switch chrismercurio Parts 5 30th September 2010 05:54 AM
Where to buy a 6-pos Input Selector Switch? Loren42 Parts 2 7th June 2010 10:52 AM
Phono input selector switch Woodsong Audio Analogue Source 21 6th March 2010 05:19 PM
Noise when using input selector switch Nuuk Solid State 12 5th July 2006 05:11 PM
Copyright ©1999-2019 diyAudio
