Instruments and Amps Everything that makes music, Especially including instrument amps.
Vox Pathfinder 10 mods
Old 1st January 2019, 11:39 PM   #11
22uf is offline 22uf  United Kingdom
Default Vox Pathfinder 10 mods
t on them.... you can buy a dented 2001 Vette for less time trouble and cash. Same in amplifiers.[/QUOTE]
I’m more after this vibe.
YouTube
Old 6th January 2019, 08:30 PM   #12
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Leave Pathfinder as-is and build a *guitar* powered cabinet, you´ll need:
* 1 power amp module. An LM1875 will add 20/25W RMS ; a TDA7294 or LM3886, from 60 to 80W RMS
* 1 Guitar speaker (Jensen Mod are excellent and very reasonable price) . Must match or surpass power amp rating.
* buy/build/beg/modify a cabinet to mount everything.
From unpainted chipboard to modified IKEA flowerpot to hole-cut-in-luggage to dead amp cabinet to custom build oiled walnut (whatever carpenter GrandPa can lovingly build )
Then you drive it from your little Vox ... same sound and distortion but at smashing loud output ... and way fatter.
this one is battery powered:
nothing new under the Sun, this is how *old* Gibson amoplifiers (think 1940s) used to be built:
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 8th January 2019, 09:08 PM   #13
Default Vox pathfinder R8 mod headroom issue?
Yesterday day I performed the led and the R8 mod on my pathfinder. I am happy with the sound but I think maybe the R8 mod has lost some headroom? It might not have, but if (on the clean channel) I have the volume set to 3 o’clock and the gain at 12 o’clock, there is a fair amount of overdrive, I think it is mainly coming from the power amp as when the volume is lower it doesn’t distort. What ways could I increase headroom? Would stacking the op amp work?
Old 9th January 2019, 04:49 PM   #14
Any ideas?
Old 11th January 2019, 03:52 AM   #15
thoglette is offline thoglette  Australia
thoglette's Avatar
Originally Posted by 22uf View Post
Any ideas?
You've already said it: instead of clipping in the LEDs you're now clipping an OP amp, which (usually) sounds worse, hence "less headroom".
Not sure where R8 is: the schematic posted earlier is postage stamp sized on the useragent-du-jour.
I've got a 15R which is going to get a center-off DPDT for the LEDs: one position they'll be in; center position will be no limiter; and position three will be an asymmetric and (initially) soft limiter. Still messing around with values.
While it's apart I'll also add the boost bypass pot,
Old 11th January 2019, 03:56 AM   #16
No, I’m talking about the clean channel - the leds where never used anyway. I’ll upload another schematic later.
Old 11th January 2019, 04:34 PM   #17
shanx is offline shanx  Canada
It's all relative, if you modify R8 to increase the overall preamp gain at that stage then of course it will distort at an earlier gain pot setting.. in this case 12 o'clock There is the tone stack and then another op amp stage where it (and possibly the TDA) are starting to distort. So you may need to play around with a value of R8 that will start distorting at high gain pot setting. Possibly ending up where you have close to the original value. Stacking op amps won't help if that is what you refer to. More output watts means either a BTL power amp or just build a bigger power amp with bigger power supply) like many suggested and keep the preamp as original.
Vox Pathfinder 10 modsHide this!Advertise here!
Newcomb Pathfinder P-1003 Cuejay PA Systems 6 24th May 2017 12:21 PM
Newcomb pathfinder PA into guitar amp getonemaker Instruments and Amps 2 13th April 2015 07:39 PM
Vox Pathfinder 10 Plook Instruments and Amps 4 8th October 2013 07:24 AM
TDA2030A replacement Vox Pathfinder 15 r Yaqoub Chip Amps 6 6th June 2013 12:10 AM
help needed for Vox Pathfinder Delbro Instruments and Amps 0 25th January 2006 08:50 PM
Copyright ©1999-2019 diyAudio
