Instruments and Amps Everything that makes music, Especially including instrument amps.
Pipe organ
Pipe organ
Old 24th November 2018, 06:34 PM   #11
stratus46 is offline stratus46  United States
Originally Posted by billshurv View Post
It can't be 11k pipes. Looks like this one BirminghamAGO POE - Stoplists . 82 stops, not all of which are real (some digital). Albert hall with 10k pipes is 147 stops.
If that is the actual stop list, I count a little over 3000 pipes, The solo division
is played from all the other divisions but only has 1 set of pipes for the division.
I count 10 ranks on great, 19 on swell, 9 on choir, 5 on solo and 9 for pedal.
Manual ranks are 61 pipes and pedal ranks are 32. Where you see "ext." that
is an extension (1 octave) of an existing rank so add 12 pipes.
Far from 11,000 but with the digital ranks for 32' stops would be a very pleasant
instrument. Clearly not tracker action as you can't couple individual ranks, only
complete divisions.
G
Old 24th November 2018, 07:39 PM   #12
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Pipe organ
Oh no doubt it's a lovely instrument. My personal fave is the kings college chapel organ in Cambridge (the original cambridge). There was a brief period in my childhood when I could sing and I did once sing evensong there. From the choir stalls you get a great perspective on the sound.
Old 24th November 2018, 07:50 PM   #13
lcsaszar is offline lcsaszar  Hungary
complete divisions.
G
Could be true because some stops (e.g. mixture) contain several ranks of pipes, 4, 5, even up to 12.
Old 5th December 2018, 05:45 PM   #14
indianajo is offline indianajo  United States
indianajo's Avatar
I very much enjoy pipe organ concerts. We have nearly a dozen a year in southern Indiana sponsored by the local chapter of American Guild of Organists. Real full frequency sound with 100 foot delay lines (sanctuaries) make for an amazing experience. I'm learning to play some on the electronic organs in my inventory below.
I'm helping install a 11 rank pipe organ in an Episcopal church in Jeffersonville IN. It has electronic control, no trackers for the 70 year old installer leading this job. The scanner-decoder from syndyne has a dual twisted pair control cable from console to pipe chamber, to allow the console to be pushed around the floor for services or weddings or concerts. Weird connectors, I had to install them myself on Cat 5 cable, or pay syndyne's price. There is a single 120 vac 3SO cord to the console also.
There are lots of electronics challenges. Turning on the blower without a second 120 vac line in the cable was the first. Since the console switcher supply only draws 3 W idle, instead of using a $120 current sense relay on the AC line to the console to activate the blower, I installed a $35 radio car starter gadget on the console and hot wired the console AC to the blower relay contacts. Push unlock button on the remote, the blower and console both power up.
Yesterday the electronics won. I was trying to hook up the Petersen swell engine that moves the volume shutters. The syndyne output board is not doing anything says volts on my DVM, although .5 v to 4.8 v swell pedal signal is getting to the console encoder board. From the decoder board in the chamber there are 16 outputs that are supposed to supply 1 of 8 14 v signals to the Petersen swell engine. (motor, crank, control boards run from 14 v). Outputs of the 2405 decoder board are open emitter transistors. I'll take a 100 ohm resistor down there tomorrow to connect the 8 outputs (one at a time) to minus to see if there is a signal with my dvm. Else the 20 year old syndyne board encoder (console) or decoder board (chamber) may have to be replaced ($$$$). Alternately I might replace that board with a stage light control circuit from the PA market since those have optical link and seem to be very cheap in the catalogs.
Another problem is the output to the zimblestern 30 v dc motor. I built a board to control 32 v from a printer/copier/fax power supply on switched AC in the basement, with the 14 v signal from the syndyne output board. The board I built also has a regulator transistor to slow down the zimblestern by dropping the 30 v to as low as 15 under pot control. It worked nicely for a few times, but now the syndyne output is turning on nicely but never turning off. Switching to another spare output is in the future, since the control signal from the zimb tab on the console is actually moving between 14 and zero properly. These syndyne boards were bought about 1985 and never installed, so no checkout under warrenty occured. I'm hoping the pipe solenoid outputs don't have the 30% failure rate I've experienced on the auxillary outputs. If syndyne failures continue at the 30% rate, a midi encoder/decoder setup ($1500) is in the future, probably midiboutique since all the other manufacturers of 5 years ago seem to have blown away in the winds of commerce.
I also built a resistor plus selector voltage regulator in the pipe chamber for the chime 40 VAC from the basement. Chimes have a seven tap 20-40 Transformer usually installed in the console, plus a selector switch, but that means 8 more wires from the console to the pipe chamber if installed that way. Traditional console setups include usually 180 wires from console to pipe chamber, something totally incompatible with a mobile console and certainly expensive these days when everything is multiplexed on cat 5 twisted pair.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 5th December 2018, 11:03 PM   #15
carlthess40 is offline carlthess40  United States
What a job. Would love to see some photos
We may be moving up to Alabama and if we do I will try to get on the good side of the organ player and see the inside of how that thing works
Old 5th December 2018, 11:17 PM   #16
Pano is offline Pano  United States
Pano's Avatar
Pipe organ
I've seen a few restored and one or 2 new pipe organs and wondered why they don't use MIDI. It's been around forever and seems robust. But now I understand the difficulty of finding good encoders.
That's for the info. Sure sounds like a giant job with all the fun and frustration you could ever want.
Take the Speaker Voltage Test!
Old 6th December 2018, 12:33 AM   #17
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Pipe organ
@indinajo -- the Organ Historical Society does an annual organ crawl at one city in the US -- we went to one in Cleveland and it was incredible. Cleveland has a huge number of great organs because of the ethnic origins -- lotsa Germans and English. I can think of only a couple French (Casavant) in Ohio.
Old 6th December 2018, 10:03 AM   #18
haskey.com - John Haskey - Residence Pipe Organ
When I built this little 2 rank organ in '88-'90 I used MIDI and wrote all the code in assembly for 8031 processors. 1 proc for each keyboard/pedals where I designed and built the switching for the keys and pedals including velocity, 1 processor for stops and 1 for decoding the pipe drives. There were actually 2 procs running the same decode program because there are 2 separate windchests and a second processor greatly simplified the wiring. Mixture stops were duplexed from the 2 ranks and the tables were downloaded via SYSEX messages from the console stops computer meaning the mixture composition and break points can be changed. MIDI only supports 7 data bits as the MSB is used for "status" (more accurately command) so transmitting 8 bits converted 3 8 bit bytes to 4 6 bits and then reconstruct. This is a little more involved for encode/decode but is a little faster in that I use 4 byte times for 3 bytes versus 6 byte times for 3 bytes if you just use 4 bit bytes.
I used a commercial MIDI combiner to merge the keyboards and stops control to 1 MIDI stream. MIDI was back then was a 31.25 kbaud link (damned slow) and you do run into just a little latency even with 2 ranks but with careful design many more ranks wouldn't cause problems UNLESS you attempted to copy data for multiple divisions. Proper receive decoding avoids the problem.
With only 2 ranks unified and duplexed there are multiple requests for a pipe to speak so there is a counter for each pipe (software) that is incremented for each turn on and decremented for each turn off. If the number is >0 it plays that pipe. Stop changes were also interesting in that a stop change has to regenerate all the "note on/off" to actually change the stops. This had to be done in the decoder because it takes WAY too much time to retransmit the MIDI data. The goal was to allow any data combination and only do what was defined and ignore invalid MIDI and I believe I achieved it.
The little 8031s were running for about all they were worth but I experimented with variable attack time from MIDI velocity to simulate tracker action response and found it CAN be done but needs more horsepower than the old 8031s could deliver.
I won't get into the chest design and pressure regulators but that was involved as well and if you listen to the example files it actually worked pretty well. What I CAN say is you DON'T want one of these as the ambient temperature and barometric pressure changes the tuning - A LOT and there are temperature variations in the room that cause to lower chest pipes to change differently from the upper chest. I was looking into a way to measure air density to force the sampler clock to track the real pipes.
I sold it before I got that far nor did I get to finish the sampler system to make it a hybrid pipe/digital but I DID get to play Gigastudio from the console just before I sold it. It would have been impressive. I wish I still had the console as it was a perfect interface for a Hauptwerk system. Oh well...
G
Old 6th December 2018, 02:32 PM   #19
indianajo's Avatar
G
On the Jeffersonville Indiana installation the church heats and cools the sanctuary 24/7 so we are hoping temperature variations don't cause tuning problems. The installer with 30 years experience has put some techniques in the pipe chamber to ensure even temperatures across the ranks. One feature is no pipes exposed to the room ambient.
Old 6th December 2018, 03:57 PM   #20
The most difficult to control was the temperature gradients that changed upper tuning vs lower tuning. I would run a fan in the room for a while to get it all mixed so you could hear it in tune for a while. You'll also find the reed pipes do not change the same amount as the flue pipes.
G
Pipe organHide this!Advertise here!
Reproducing a 16Hz pipe organ note Old Ears Subwoofers 131 12th June 2016 09:38 AM
Variable Port Lengths/Diameters? Like a pipe organ... justinzane Subwoofers 15 31st August 2013 09:11 PM
Looking for jazz bass and pipe organ toenail Music 8 16th January 2011 06:56 PM
DIY Home Pipe Organ ReidK Instruments and Amps 7 16th January 2011 06:43 PM
Pipe Organ sub workout Circlotron Music 3 10th April 2007 01:01 PM
