Instruments and Amps Everything that makes music, Especially including instrument amps.
Jet City JCA 22H OT replacement and minor mod
Old 17th January 2019, 04:17 PM   #21
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I wouldn´t worry about 3mA difference.
Any decent transformer must take that and more, say at least 5mA difference, wouldn´t be surprised at them standing 10mA.
"In the old days" , I guess amp manufacturers matched tubes, but not so sure about that, I bet workers just pulled needed tubes from the proper shelf in the warehouse and installed them as-is ; then if amp worked as expected , fine.
I see NO tube matching or even current measuring notes at all in any old Fender/Marshall/VOX schematic.
Fender just spec´d "-52V" for 6L6, Marshall/Hiwatt and others "-38V to -40V" for EL34 ... period.
Smaller tube amps were often self/cathode biased so that tends to self-adjust.
Of course tubes were more consistent but mainly: bought in large batches from same manufacturer, so ...
As of "Joe Public", he just bought random tubes from his friendly "Radio and TV Shop" and plugged them in.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 18th January 2019, 01:15 AM   #22
PKI is offline PKI  United States
PKI's Avatar
Originally Posted by Kay Pirinha View Post
I'd rather be worried about the vendor's carefulness in matching tubes . It appears that they measure and match at only one operating Point - or they don't match at all and just charge their customers.
Best regards!
Actually I am pretty upset with Tube Depot. I got all new tubes for the head, 2 Tung sol 12ax7 for first two tubes in the preamp as I remember I used to like them before, 3 rest are JJ and 2x JJ el84. I already commented on matching of el84, but what is most upsetting that it looks one of the tung sol tubes is bad. I had this fizz and weird foreign sounds coming of the amp and I've checked everything. So neighbor of mine had two old tung sol in his closed. I swapped mine pair and weird sounds went away. I swapped JJ into same place and sound I good again (more gain and compression with JJ, but with no fizz or foreign sounds). I guess not buying from them anymore...
Old 6th February 2019, 05:41 PM   #23
PKI's Avatar
Just to bring up to this discussion (monologue mostly, but whatever hehe). I finished with my amp. Re-did some chassis wiring as it was a bit messy, changed poly caps to Wima(most I end up having in my stash), brought all values in the preamp section to the ones in SLO and added some switches from SLO schematics.
Amp sounded great! Next I what I did I increased those caps in PSU filtering. First 47uF —> 150uF and two 22uF —> 47uF. The result was controversial I must say. The bottom end and overall sound became more tight, even. I absolutely love it on hi-gain settings, so great. However, in lower gain/crunch-clean sound amp lost some of the dynamic range and that tube character to react to how hard you pick. I does lack some of the sponginess on crunch channel now. Do you think it is possible to have both? what if I change values of those 47uf back to 22? Or anything else?
Old 19th February 2019, 11:48 PM   #24
PRR is online now PRR  United States
PRR's Avatar
From too-long PM> 300-320 would be a sweet spot for the power tubes. However, slo100 preamp need 360V
VVR, Power Scaling™, etc.
Power Scaling Kits
Old 20th February 2019, 04:04 AM   #25
PKI's Avatar
Power Scaling Kits
thank you! I do not quite get it yet, but I will read about it.
Another thing, I see that I was mistaken and the amp is actually fixed bias, right? So I can just drop the voltage of B+ and screens "manually"
Old 20th February 2019, 06:44 AM   #26
PKI's Avatar
Messed things up. You can use diodes in cathode biased amp not fixed...
Jet City JCA 22H OT replacement and minor modHide this!Advertise here!
minor hum problem ubza1234 Tubes / Valves 25 21st October 2013 10:54 AM
Minor crackling in new valves theskintman Tubes / Valves 0 15th March 2007 03:10 PM
Best Toccata & Fugue in D Minor? ReidK Music 11 19th December 2006 11:21 AM
Speakers..minor ones.! ajju Multi-Way 6 30th August 2003 09:15 AM
minor software update f4ier Multi-Way 0 25th November 2001 05:47 PM
Copyright ©1999-2019 diyAudio
