Instruments and Amps Everything that makes music, Especially including instrument amps.
JCM800 2204 Phase Inverter issue and other
Old 11th November 2018, 05:15 PM   #131
SimoS is offline SimoS
Hello. Installed the new OT = no more redplating and full output power again
I'm in doubt, now, about trying however to reduce B+ (switchable?) to complete the transformation to a old style ('80) JCM800 2204. Your opinion?
In any case thanks again for your patience and your suggestions: I learnt a lot!
Old 12th November 2018, 12:35 AM   #132
Koonw is offline Koonw
Congratulation! But you should protect the OT from shorting happened again in future:
1) Install a 100 ohms 2 watts resistor across the secondary, this acts as dummy when the speaker/load is accidentally pull from output jack.
2) Install diode protection in Primary as in newer Marshall amp
3) HT can be reduced by adding series resistor in each secondary of power transformer before the rectifier bridge. If max. AC current drawn is 200mA, then 100 Ohms resistor will drop 100*0.2=20V on each secondary AC tap. So 20*0.2=4 Watts, you can rate up to 10 Watts resistor. Alternately you can reduce the screen voltage by simply adding series resistor after choke T3. (Remember reducing screen voltage is more effective than reduce plate voltage in term of plate current reduction hence possible red plating)
Old 12th November 2018, 09:51 AM   #133
turk 182 is offline turk 182  Canada
time to celebrate!
JCM800 2204 Phase Inverter issue and otherHide this!Advertise here!
Marshall JCM800 2204 clone, need help Rudd3r Instruments and Amps 2 8th January 2017 04:21 AM
RCA phase inverter? KTMrida4life Car Audio 5 19th September 2015 10:33 PM
JCM800 / 2204 style build hum / buzz plea for help paul525715 Instruments and Amps 14 17th July 2012 09:41 PM
JCM 800 2204 PT issue Dr.R Instruments and Amps 5 2nd March 2012 07:39 PM
Phase inverter ThSpeakerDude88 Tubes / Valves 37 29th August 2007 04:15 PM
